What have you done to your 100 Series this week? (13 Viewers)
Dual Battery Install--Problems. Need help!
Good evening gents and dames. Let me start by saying...i am not an electrician. I installed a dual battery set-up using the Redarc 12v smart battery isolator. I have a 100amp fuse between the isolator and starter battery and the same between the auxiliary battery and auxiliary terminal on the isolator. I am running 4 gauge wire. The auxiliary battery is in the corner of the engine bay near the passenger (Slee Battery tray) and the fuse is behind the passenger side head-light in the corner. Maybe 2 feet from the auxiliary battery. The isolator is bolted next to the radiator, behind the grill. My PROBLEM is that when i turned the truck on it did not want to stay on. The rpms would decrease and the engine would die. After a few attempts and gunning the engine the truck eventually stayed on. I turned it off, took a shower and went back to drive it thinking maybe the starter battery needed to charge. It was disconnected for a few hours yesterday. On my drive I had to stop for traffic. Truck died. I started it, drove about two blocks and had to stop at a light...the truck died. I turned around and came back home and sat in my driveway idling for a minute or so and it was fine. I can include pics if necessary but thought the description would be enough for some smart and wise soul(s) to help me troubleshoot.
Thanks.
Having a very hard time visualizing how you have this wired—pics might help. But maybe on a thread specific to this mod. You’ll have better results there than on “what’d you do to your rig today?”
Did the red arc isolator instructions recommend fuses in those locations and that amperage?
I'd start a thread on this issue instead of talking further here in 'what i did'. I have a REDARC BCDC, but not sure if you're referring to a manual/switch isolator. Take some pictures with details of what you installed to a thread and maybe folks can help. In the meantime, I'd remove positive/negative connections to whatever you installed to islolate [h0h0!] the cause firstly.
I ask because my truck as a mice nest under the intake but when I consulted with Paul @2001LC he was really against the idea of pulling the intake unless there is a real need for it. He was of the opinion that it can cause debris to fall into the cylinder head.
I am, a very big proponent of cleaning top of engine before removing the Intake Manifold. Taking the time to clean before, during service to insure no debris falls into intake ports of heads and remove any that does is critical. Unfortunately I've seen all to many 2UZ cylinders, valve and values seat damage from debris failing in.
Removed running boards, roof rack, rear spoiler, and fender flares. I have had my hundy for about 4 months, and I have to say I should have done this the weekend I bought it. It looks so much better without all of that "stuff".
What did you use to cover the mounting holes?
Got a few overdue projects wrapped up...
After having the Hewitt Tech Gen-II SAIS Bypass Kit sitting on my work bench for the better part of 6 months, I got it installed. It was nerve racking splicing in the the wiring into the engine wiring harness, but everything went together well. Thanks @hewitttech for the great kit with fairly straight forward instructions!
I got around to changing the cabin air filter. The old ones had ~49k and 4.5 years on them.
I also changed out the high idle vacuum lines that come off the valve on the PS pump. They were pretty cracked and dry.
Added SLEE main battery upgrade, Alu-Cab tilt fridge slide, Odyssey 31m-pc2150 and installed fridge
Finally got around to adding a switch to my DRL's (Daytime Running Lights). I made up an On/Off switch with pigtails, God only knows how long ago...and its been sitting on my computer desk just begging to be installed.
I finished up some chores around the Ranch a bit early...so figured I'd stuff myself up under the dash and do the surgery needed to splice in the switch wires.
I'm sure its no big deal for you younger/slimmer guys, but I'm 6'-5"...250 lbs and 66 years old. No problem finding the connector and appropriate wire to snip (Red w/Blue stripe). But getting the tiny wire stripped back, the butt connectors in place and crimped in such tight quarters wasn't much fun. I sure as Hell didn't want to withdraw myself until all was done, because getting back there would have been an ordeal.
So.... holding a flashlight in my teeth, reading glasses on, wires strippers in my right hand, crimpers laying on my chest....I went to work.
Finally got it done and the connector plugged back just as I started getting a cramp in my left leg. Kept my fingers crossed that all was right and tested the switch.
Eureka....! We now switchable DRL's. Not entirely sure it was worth it.....but I have it now.
Plan to poach deer at night?
No, got a freezer full from 'legally' hunting them. And I have deer in the pasture behind my house day and night anyway, thanks.
Yummmm.....
I just don't see the need to always be burning the high beams, regardless the situation. They are a safety feature 'supposedly' but I've observed over the years that folks have learned to ignore (not notice) them. They don't really seem to make your vehicle 'stand out' anymore as people have become accustomed to them. With the exception of it being 'dusk' and some fool not yet turning on their headlights, I'm not convinced they do much anymore. Anyway....I have the choice now of running them on or not.
Damn how was the steering rack job? And did you do oem control arms or aftermarket?
I just stroked a check on the steering rack and control arms. Local show did everything for $850 so couldn't pass it up. Went with OE Brand new rack, moog control arms and tie rods.
Nice. I thought the u-joints had to be shimmed and balanced as well??
To clarify- on a brand new Toyota drive shaft it already comes set up with the correct shim (snap ring) thickness based on it having a brand new yoke & spiders.
If you are replacing u-joints (with Toyota u-joints) on your existing used driveshaft you would (should) check and/or replace the snap ring. Over time, the yoke wears, especially on lifted rear axles due to the increased working angles. I think some driveshaft shops dont bother to follow this step when replacing u-joints and is the reason some experience driveshaft vibes post new u-joint install.
  • Back
