What have you done to your 100 Series this week? (19 Viewers)
Replaced my aging rear hatch struts with new units from @CloudCity 's amazon store. Mine would hold the hatch, but not lift it. Kind of a 'it stays where you stick it' sort of thing.
New ones went in super easy and lift the hatch really quick.
New tires for the long drive to Pismo and back. Desperately needed to get off of the mud tires that were on there.
Hankook dynapro AT2 RF11, 285/70/17. Semi impulse buy the day before the trip. Pleased so far, very quiet on the road, did great in the sand. Aired down to 12 to 15 without problem.
What were you wearing before? How's the ride quality?
I love my Coopers off road, and they look great, but they ride like s***. I'm casually looking around at something a little more road friendly since this is also my highway vehicle.
I installed the scangauge mount by @BenCC . Nice product. It did require some sanding for a smooth finish, as was suggested by Ben. He actually recommends using a filler putty, but I tried my luck with a palm sander and ended up getting it satisfactory without the putty. Krylon khaki paint for a really nice match to the OEM trim. For install, I looked into the other threads for Ayune's product. I did end up removing the A pillar trim (OS handle include), and the two sun visors. The extension cable I bought had a big chunky block where the two ends meet, but I was able to shove it deep enough in the head liner that it laid flat without a bulge. Fit of the product was very good, if even snug to the point of needing to strategize pushing it in. On mine, I did sand down two of the tabs to give the part a flusher fit to the face of the console.
Prior to these it was on nitto mud tires from PO. They road like S*** as all mud tires do. Vibrated everything in the drivetrain, were noisy and of dubious value to a vehicle that now lives in the desert (of course they will be for sale in the used tire section and labelled as the best mud tires ever)
To answer your question, anything compared to the old tires is going to be miles better. They are smooth, quiet and ride very well. However the Icon suspension probably doesn't hurt. Hankook do a 30 day money back if you don't like them. Just FYI the older version AT 10 are about 26 dollars cheaper and per the guys at discount "the hardest wearing tire we have ever had" That tire also has a more aggressive looking tread, might be worth a look depending on what off road stuff you get in to.
Saturday I spent half the afternoon trying the ratcheting wrench and strap wrench method to get the rear shocks out of my LX they were throughly rusted on and it was kicking my @ss. Today I caved and drilled two access holes from the top....... HOLY CRAP I should have done this from the very start. Makes it soooooo much easier. Plugs are easily sourced online for the 1.5” hole.
Measurements taken from user DRJMAN
Driver side:
About 4 inches to the rear from the front tie-in loop and about 4 inches towards the middle of the
vehicle.
Passender side: 3 inches back, 5 inches in
Driver side:
vehicle.
This is the way to do it if you're in the rust belt, no other way. There's a bunch of holes in the rear cabin anyways, what's another one? Just plug it so water doesn't get in and you're good, makes future servicing easier too.
Awesome man, glad you're pleased! One of those little-cost, huge-reward things that we all tend to let slide for too long. I finally changed my hood struts when it landed on my mechanic. Since the LX has a built-in guillotine (attached grille), it seemed like a nice thing to do.
Awesome man, glad you're pleased! One of those little-cost, huge-reward things that we all tend to led slide for too long. I finally changed my hood struts when it landed on my mechanic. Since the LX has a built-in guillotine (attached grille), it seemed like a nice thing to do.
I'm sorely overdue for new rear struts...
lol guillotine, as a mechanic, this is my biggest pet peeve, a hood just sagging or falling on me while i'm in the engine bay. This hood is heavy as hell too.
I am glad you like it. I am finalizing the multiple- rocker switch mount for that same location.
I started a build thread to document all my makes.
Driver side:
vehicle.
Mine aren't rusty, but I need to replace my rear shock bushings and cushions. I was under my truck replacing rear control arm bushings and even with the spare out I couldn't see the shock mount. Holes might be the easiest option.
What plugs did you use? Did you seal with undercoat or something similar?
You are all doing it wrong, OTRAM's method is the easiest no matter where you live--sawsall to the top of shock just under the mount. Takes 25 seconds of cutting and you're done.
Timing belt & tensioners, water pump, radiator hoses, and brake fluid flush. Only thing left to baseline...front wheel bearings, CV's and dif fluid R&R.
