- Joined
- Jan 4, 2014
- Threads
- 94
- Messages
- 3,042
- Location
- Little Rock, Arkansas
- Website
- www.facebook.com
You might have recently seen in the photos thread that I upgraded my engine-ground wires. No I don't have an upgraded alternator at the moment but plans for one are in the near future so that is partly why I decided to do this mod now. I went with 1/0 pre-tinned copper lug terminals from Little Rock Bolt & Supply Co. and 1/0 tinned OFC copper ground wire that I found at Home Depot. First step was taking pieces of string to measure the different lengths of wire that you will need. I came out with
I found two ground wires for the engine but if anyone knows of more please let me know. One between the heater tee's:
And another one that goes from a bolt on the side of the engine to an area next to the main fuse box and dip stick under the hood. I didn't get a pic of it originally but here is one with the new addition:
Both:
Notice I said addition. I did not replace the factory ones, I simply added on to them. I took a small wire wheel on the end of my power drill and got all the dirt and grime off the grounding surfaces. I then used 220 grit sandpaper to clean up the factory ring terminals which really weren't bad to begin with. I have heard this could potentially benefit more by keeping both grounds...? Not 100% sure on that so please correct me if I'm wrong, just something I've heard. I will post more pics tomorrow of the battey-ground wire. It started raining as I was finishing that install so I didn't get any. It ended up being a little trickier that I thought. Pre-upgrade: 14.2V Post-upgrade: 14.66V
My next objective is to upgrade the alternator-power wire. Due to the location of the alternator this is going to be a much bigger challenge. The power wire connects to the alternator by what I believe is a connector on the backside. I removed my skid plate to see if I could get at it from the bottom but no luck. So now I have two questions: 1) Has anyone else done this and have experience with upgrading the alternator wiring without actually removing the alternator, 2) How could I attach the appropriate connector to the 1/0 cable (and where can I find it)?
- Engine-Chassis: 2'3" and 1'
- Battery-Chassis: 7.5"
Both:
