What Did You Do with Your 80 This Weekend? (108 Viewers)
This is for the parts gurus out there...
Is there a Toyota part number, or close substitute, for the tape that secures the AC line insulation as it approaches the compressor? Mine is about to unravel, as shown at the center of the image below:
Aluminum tape for ductwork would work
One of the projector shrouds came loose during some washboard on a trip, used the opportunity to upgrade the high beams. Quad projectors now, with 2.5" morimoto HB LED. Not an easy install, required cutting a large amount of the reflector to mount the projector without it hitting the glass lens.
Probably the original steering shaft seal and fuel filter. I replaced my shift indicator with a nicer used one when I bought the truck, but found out they still make the 93-95s(?).
View attachment 3830295View attachment 3830297View attachment 3830302
Did you make the shift indicator overlay yourself or find it somewhere?
Outsane…..On your website….quantity 1 is for 2 brackets correct? Thanks, I just want to be sure.
Comes with two brackets and bolts
They are each different
I just made a pinion seal driver yesterday after working on a buddies rig.
Also the same tool for the front crank seal
I like the post holder
Took the manual swap out for the first time on some trails! She did great aside from a small electrical issue. Kept up with the 3x locked big boys haha
Kept blowing gauge fuses, and acted like battery was dead when I would turn it off then try and restart. Noticed the fusible link connector was exposed and was sparking off the power steering bracket when I went over bumps! Insulated and moved it and so far it’s good, still blowing gauge fuses randomly.
