What Did You Do with Your 80 This Weekend? (38 Viewers)
I made my scanguage light up up less and match the dash a little better...
Before:
After:
Check this out friend of a friend ask if I wanted a Landcruiser catalog and I said yes, of course. So old, that only had FJ80 and promise of parts to come in near future. And bonus vintage sticker inside.
Have a great day :flipoff2:
@AgentOrange Which lift are you running? Are you planning on using any bumpstop extensions? I'm at a similar point and have seen a few different paths to accommodate for tire clearance F/R.
Thanks,
Jeff
These are Dobinsons VT heavy springs, 3" rear, 3.5 front. I just have the bumpstops dropped an inch. On the 315s with no bumpstop extensions I didn't rub almost ever, but these are wider and taller. Definitely recommend a heavy duty rear stabilizer and heavy duty links. It's downright terrifying without the bar with weight in it, and my stock links worked for maybe half a trip before letting go.
How’s it going ? So far so good for me!
I'm not finished. I need to shorten up some wires to my rock lights. Make the wiring look better than it currently does, and wire in the the power to the panel.
Where did you tie in your power to the panel?
Played rescuer to a jeep
Those headlights are me pulling with the winch
EIther that's a bad photo angle or the needle is way off. I replaced my TRD boost guage for that exact reason. The needle should be centered on "0" right now.
Chasing some driveline vibe in the rear. and noticed there was some slop in the driveshaft. Replaced with a new one this afternoon from Boch Toyota South. Haven't had a chance to test drive yet. Stupid work....
Maybe he lives in a negative atmospheric pressure environment.
