I made my scanguage light up up less and match the dash a little better...
Before:
After:
Before:
After:
How’s it going ? So far so good for me!I just got the same switch panel. I have 5 empty spaces to fill.......
Very nice. I like that display!. Had to go with the green on my panel to halfway match the Toyota green interior lol.I made my switchpro light up up less and match the dash a little better...
Before:
After:
@AgentOrange Which lift are you running? Are you planning on using any bumpstop extensions? I'm at a similar point and have seen a few different paths to accommodate for tire clearance F/R.Got my 37s on. Flexed it just enough on the planter to see where I need to trim on the rear fenders just a touch. Excited to get it right
These are Dobinsons VT heavy springs, 3" rear, 3.5 front. I just have the bumpstops dropped an inch. On the 315s with no bumpstop extensions I didn't rub almost ever, but these are wider and taller. Definitely recommend a heavy duty rear stabilizer and heavy duty links. It's downright terrifying without the bar with weight in it, and my stock links worked for maybe half a trip before letting go.@AgentOrange Which lift are you running? Are you planning on using any bumpstop extensions? I'm at a similar point and have seen a few different paths to accommodate for tire clearance F/R.
Thanks,
Jeff
Cough cough…. Fuel pressure regulator…Replacing some maintenance items, replaced vacuum lines and installed the CDL switch. View attachment 3260727View attachment 3260728View attachment 3260729View attachment 3260730View attachment 3260731
Caught cough...throttle cable...Cough cough…. Fuel pressure regulator…
Cough cough…. Thanks lolCough cough…. Fuel pressure regulator…
Cough cough…. Thanks lolCaught cough...throttle cable...
I'm not finished. I need to shorten up some wires to my rock lights. Make the wiring look better than it currently does, and wire in the the power to the panel.How’s it going ? So far so good for me!
It’s so satisfying to install that stuff. Looks good!Laid down Kill Mat and 150 mil sound deadening foam mat. Once new carpet come is will pull the front seats and complete the insulation and sound deadening. Plan to pull the headliner as well.
Maybe he lives in a negative atmospheric pressure environment.EIther that's a bad photo angle or the needle is way off. I replaced my TRD boost guage for that exact reason. The needle should be centered on "0" right now.
