What Did You Do with Your 80 This Weekend? (50 Viewers)
Exciting weekend for the slug...took some shock measurements for a buddy...
Been doing some odds and ends from a never ending punch list of items...
Pushed the rear axle back 1.5", need to adj UCA's but after fighting with them for the last week between PB Blaster, heat and then cold, and sheer force I've given up. Time for some MetalTec UCA's to match my lowers ;-)
Oh, also broken down all 5 beadlocks in an attempt to balance them "better", so far they are better without any balancing media at all... go figure?
And lastly finally mounted a steering dampiner back on, never put one back on after the high steer.
-A
Camping, hiking and off-roading in the Borrego springs area with the fam
What looks like the sun was the biggest brightest moon I've seen in a long time
Wifie doing some laps
I don't know because i bought the consoles without the gauges.
Buy a small sheet of ABS and cut to fit the hole properly. If it leaves enough room for the backside of the switches.
Short daylight be damned! Took the wheels/tires off tonight. Had an hour and a half after work to blow leaves til dark so it was give up or keep rockin. Going to strip the tires and change the color of my wheels.
Changed out my front pads. Measured out the rotors and I just passed min. width. Time to order up complete brake set up and have it all installed before Turf n Surf!!!
I've got a pretty big punch list to get through. No idea how in the hell im gonna get thru it all. Ugh.
Oh and in my "spare time" I started with the Axle Cheatsheet that @DARKNESS did up and did vectors for the whole thing and put everything into one comprehensive chart. After chatting with a few people I figured I would do a run of posters and t-shirts :D
But not until I can confirm there are no mistakes first ;)
View attachment 1339361 View attachment 1339362
That is awesome. :cheers: Especialy because I could wear it and just stand around while someone else wrenches like I typically do. :doh:
