What Did You Do with Your 80 This Weekend? (45 Viewers)
Finally got around to installing my YODATEQ antenna mount from Frank. THANKS Frank! Great mounting solution.
As well installed my 4' Firestik antenna with HD spring.
Perfect clearance for the coax cable.
Slee CB mod.
Then a super boring oil change with super cheap boring regular oil.
I would buy an 80 series in each color if I had a car collection plus Land Cruisers from the past and present. Love love okve them!
Went to Kings canyon and went on a hike to mist falls! Ran out of battery once I got up there! Saw 2 Cubs and a mother bear...or a papa bear, couldn't tell cause I didn't want to get close enough to lift up the skirt!
Rounding the finish line on this diesel swap, this weekend I got a few things sorted.
  • Finished the LSPV delete and bled the brakes.
  • Modified an a ucura Guage pod and installed Boost and Pyro gauges.
  • Put the ARB bumper and winch back on.
  • Installed Slee headlight harness / Aux harness.
  • Routed battery cables through to distribution block in back of truck.
  • Fabricated a 3" exhaust downpipe l then painted and heat wrapped it.
Mocked up another inflator
With the valve closed, left gauge reads tire pressure and right gauge reads source pressure
Open it up and they equalize
And the larger screw on chuck is easier on the fingertips than the dually extensions on my old setup :cool:
What chuck is that? I like it. I'm using a Tru-Flate 17-373 and it's worked well but I like this screw-on type.
Wow, you always have great picture to share.
What camera do you have?
Looks cool but what is it?
Half Jeep half Toyota?
Thanks. I'm using a Nikon D90 and Nikon 17-55mm f2.8 lens. That was a Jeep with a lot of cutting and welding. Lots more pics in my thread.
