Which lights exactly did you end up using?
Just some cheap waterproof strip lighting. I've had it sitting around for awhile now and looked at it today and thought I might as well use it for the tent as the most recent HF light is about to go out.
Newborn baby girl at home so not too much action on the travel front, so decided to add more weight to the rig and increase my mall cruising status also.
Form / Function
Easy / Difficult
Useful / Useless
Cheap / Expensive
Precise / Sloppy
Poser / True
I like opposites.
Also fitted shifter surround courtesy of @mudbludger and his top notch fibreglass skills :cheers:. Bit of plastidip, pinch weld and an eBay leather boot and it looks better than factory :beer:
@RiFF RaFF If you are mounting a CB antenna use a spring. I've bent the crap out of my yoda mount using a 3ft firestick without (yes my bad)
You betcha! I'm hoping I can match up my front CB antenna for better output. If not - may just relocate the antenna to the rear mount. Thanks for the spring information!
better wiring than i would do!....I am thinking that your battery is dead....just replace your battery and it should work quite well!..:moon::moon:
First thing that came to my mind was the cup holders, not the battery.
I'll change the transmission fluid first and see if it makes any difference. If not, I'll move to the battery. I may have to be moved to the PS.
I tester the crap out of those skidplates last week!
:cheers:
Rad! I'm hoping to get into trouble next weekend somewhere between Tahoe and Yosemite :).
Installed "Rear Antenna / Light Mount COMBO PACK" I ordered from Frank @yodaTEQ . Nicely powder coated, and very strong! Plan to mount an antenna on the driver's side, and LED work light on the passenger's side.
Don't mount antennas on your mount! They are mainly for lights or other light objects!
They are really cool and well made but not for antennas or of sorts! Leverage is the mounts nemesis!
Swapped out my ARB awning for a Tepui. Figured as a Tepui dealer I needed to. For all practical purposes they are identical.
