Took all this apart, scotchbrited and freshened up the paint job that I did in a hurry last time....
Actually took my time cleaning it up and painting and clear coating this time. Still not perfect but better than it was by far. Not a fan of chrome. Even though my door handles are still chrome... Also redid the center section of my hood and my cowl. Muy bueno.
Can I just refer to my previously more lazy/hurried self as "previous owner?" 😂
On a negative note...my hi beams don't work after doing all of this...time to look for an electrical gremlin I suppose.
The hi beam indicator lights up on the dash, but nada from the LEDs. All other lights function properly. Maybe the ground needs cleaned up...we shall see
No good deed goes unpunished I guess..haha...Hate it when you try to do something that is not exactly needed but worthwhile and then something else goes wrong.
Figured it out...polarity is a b**** 🙄 the LED 9005 bulbs I have need to be plugged in opposite of the retainer clip...after taking it all apart I forgot this fine detail...back to regularly scheduled lighting.
Took a road trip to visit Cody at Endless Off-road Solutions outside San Antonio. Always a pleasure to meet a fellow Land Cruiser enthusiast and see a shop full of fine specimens.
I have never seen traction boards actually make a difference. Do they even work? I just assumed they were overlander bling bling
There's no shortage of people that have them purely for show, but they are an effective tool in situations like yours. I've used mine a lot and they have helped a lot. I've been on trips with friends where we had as many as twelve sets of Maxtrax in use to get through a particularly difficult section of trail. Couldn't have made it without them.
That shovel probably did more work than traction boards would have. Those are good conditions for using traction boards. I’ve got a set that I wouldn’t hesitate to take in some situations. That said, they stay in the garage for the most part.
They make a helluva difference if used properly yeah. Overlanders don't ever use them they just look cute 😂
But for wheeling solo in sand and snow they're a good bit of kit to have
What about a PullPal? Do they work as well or better?
A PullPal is big, bulky and heavy and not easy to store in a rig. They work well as long as the ground you want to use it in is soft enough to allow the blade to dig in. If you can't get the blade to dig in you'll be using a shovel to get a deep enough hole for the anchor.
As for being better or worse than traction boards, it's apples and oranges. Both are good but have different uses and each one has certain situations that it works best. Traction boards are for situations where you're stuck but not stuck enough to require a winch. They are easy to store on or in the rig and easy to use. Because of the ease of use they are often the first option for self recovery. But there are situation where they won't get you out and you'll need a winch. In those cases a tool like a PullPal is useful especially if you have no other options for a winch anchor point.
My opinion is that if you do a lot of solo traveling you can't have too much recovery gear. If you always wheel with someone else or a group then you may not need more than a good set of shackles and a recovery strap. Someone in the group is likely to have a winch and in a group you always have a winch anchor point. I do mostly solo trips or trips with two-three vehicles. I have a winch, traction boards, straps, kinetic ropes, several shackles, a shovel, a hilift, a bottle jack, but no winch anchor like a PullPal. I've been stuck bad enough on a trip with two rigs that all of my gear was been used and still didn't get me out. The winch would have worked since I could have used the other rig as an anchor point but the other vehicle was behind me and had no way to get in front of my rig. There was NOTHING around that could be used as a winch anchor point. I spent 3 hours in a soft, silty river bed sunk to the frame. The traction boards didn't work, attempts to snatch or strap the vehicle out didn't work. Digging was futile since the holes immediately filled with more silt. If I had a PullPal it would have been a very quick recovery since the ground was soft enough for the blade to sink deep and anchor well. But since there was nothing around to use as a winch anchor and I didn't have a PullPal we were stuck until fortunately another vehicle came along on the opposite bank of the river in front of us and I was able to use that vehicle as a winch anchor. The traction boards were used to help get the truck higher and break the suction and the winch pulled me out quickly.
Every tool has it's place. There will be times where that one piece of gear that you don't have will be the exact gear that turn a long, hard recovery into a quick, simple recovery.
IMG_6909 by Adam Tolman, on Flickr
IMG_6910 by Adam Tolman, on Flickr
IMG_1506 by Adam Tolman, on Flickr
IMG_1505 by Adam Tolman, on Flickr
IMG_1515 by Adam Tolman, on Flickr
IMG_6913 by Adam Tolman, on Flickr
IMG_6918 by Adam Tolman, on Flickr
How are they used? I have never actually seen them in action. Do you have to jack the vehicle up or dig out under the tire to get the board under the tire? Or can you just stick it in front of the tire and let the tire pull it under?
37s the new 35s
17x9 -38 hub-centric
I know exactly what you mean. I did a carbon copy of the picture at the top down in South Texas in 2002 right up to the axles...only I was alone. I tried everything to get my truck out and finally resorted to cutting down some small mesquite trees and sticking them under my tires. It worked and I got out! I guess you do what you have to do to get home!
You don't have to completely dig out under the tire, just enough that the tire can grab the edge and pull the board under. The board itself can usually be used as a shovel. Flip it over and use it upside down to dig. Obviously that works better in soft ground like sand/snow/mud. You may need a real shovel in hard dirt/rocky ground. Look them up on youtube. Lots of videos of how they work.
What was culprit? I've got to deep dive into my cruise control to see why it's not engaging. The light comes on, but doesn't set the speed.
Exactly what was happening on mine. It was a bad speed sensor. Toyota doesn't make them anymore so I found a thread on here where a guy bought a replacement from an Australian company.
