What did you do with your 60 this weekend? (9 Viewers)
I'm adding a spal 10" pusher fan and a Davies Craig fan controller. I'm not relying on this to help the engine coolant temps. They are in control but the ac really falls off at idle after a few mins. This is similar to what certain rest of world 80 series got. Besides this, I'm looking to add some ceramic UV blocking tint once I find new inner window felts.
I'll space the condenser line up with a 1" spacer and seal the fan to the radiator with some dense foam. This controller also allows me to easily add another fan. I could fit a 6" fan on the other side.
Summit Racing fan controller
This is the fan controller. It was really simple and it uses a temperature contact probe, but I can also swap it for a coolant temp sensor.
I'm using this thread as a reference.
Looking good! This is where I am at. Still need to wire it up and finish a bracket.
Ordered A/C parts: Compressor, Condensor + Rcvr Drier....all Denso. Hopin the Evaporator is good. Cant even believe itll have A/C.....crazzzzzzzzzzy
Where did you order all your A/C stuff from?
that’s next on the to do list for my 60!
a fellow member was kind enough to LIVE REAL Time Test fit and Function Test , and shoot a very high quality TECH. Video as well
of my new
84310-60181-R
i am truly grateful to be surrounded buy kind fellow MUD members in every way :)
Added a t-case extension to my DD FJ60
Added length gives more leverage for shifting, plus do not have to lean over so far to reach the lever.
View attachment 2709289View attachment 2709290
Ok, I am liking that upgrade..cheap too. The site lists that is it for the 80/100/LX450/LX470........assuming since you are showing it that it would fit my 60 without any modifications???
Absolutely no modification and very easily reversed. Just unscrew the t-case knob and screw on the extension.
Took it wheeling with my dad, brother and a few friends. This was the first run since finishing the 1HZ conversion, and everything worked great. We had it up to 5,000 ft without even a hint of smoke, and heading up into the mountains in 105* heat was a good test of the cooling system. I'm really happy with how well its running.
The H55 + 4:1 tcase gears have totally changed how this truck drives, its amazing on the trail.
Just screws on eh? Genius!!! Was always a PITA to shift in/outta 4H4L...moat excellent.
Just ordered one as well. Will probably do the 2-Low mod while messing with it. I wonder if anyone could fab up a new shifter decal to show the 2-Low. That would be sweeeet! Anyways I degress...
Whats the 2L mod? #Thanks
This certainly isn’t as cool as the tailgate storage hatches, but it does provide a useful space for spare drive belts. Will do the same to the other side for spare cooling system hoses.. Just need to undo the Phillips head screws to gain access - but this is for emergency spares only so that doesn’t worry me…
2lo mod -
