What did you do on your 70 series today? (31 Viewers)
I think it is black matte paint with a couple of clear coats on top - i thought about powder coating it but this was faster and the guy that painted them gave me the same warranty- :)
Somebody forgot to latch the tail gate.
Back together .. complete with stainless 2209 airial with 00 buckshot tip..
Installed a new OEM blower motor today.
Last picture shows the all important blower motor resistor (87138-90K00 for 24v 7x series trucks).
I swapped the resistor out as well and put the old one into my truck spares box.
I like that, you should provide more info on the pneumatic throw switches I've
never seen them before.
The switches are pneumatic machine application. The have a push in air line lock like the arb uses on the compressor, no electrical connections. So the compressor activates and sends air to the pneumatic switch which then operates the lockers. Thety are spring loaded to the off position and when flipped off the air bleeds off through the switch with a light psst noise. That last part may not be too attractive to some but I like it. This eliminated all the wiring to the arb rocker switches.
Learning the ways of valve adjustments from Senor Robbie.
Replaced my door panel clips! Finally!
Removing the old busted clips.
New clips!
And all clipped in!
I no longer have to use a magnetic koozie to keep the panel corner from popping out of the door. Thanks @wct49 for the multifunctional koozie!
The carnage.
Another little project, prepping for an upcoming trip. My own version of an attic. This will serve as my coat storage space. Not as nifty and clean as @perrobravo 's set up, but it'll do.
Nice.
