Current project: rebuilding a Kawasaki FD501V, water cooled, V-twin from my John Deere LX188 lawn tractor (not mower, the mower works fine, it's the tractor I have a problem with).
Current situation: the resident geniuses at JD decided, in their infinite wisdom, that sandwiching the frame between the lower engine case and the drive pulley/PTO would be an ideal design solution. Note: this requires anyone wishing to remove the engine to first remove the bolt in the lower end of the crankshaft, remove the PTO and then remove the engine drive pulley, prior to removing the engine, which is required for access to the pistons, camshaft, oil pump, etc.
Current problem: after fabricating a puller (neither my 2-jaw nor 3-jaw pullers did more than bend the flanges), I now have drive pulley separated from its shaft, and the engine on the bench. I now have to remove the drive pulley shaft from the lower end of the crankshaft, so that I can continue with the teardown. As you can see from the photo, the pulley shaft (a far-too-complicated and expensive part, IMPO) has a 1.5" hex (across flats) and is situated 0.185-inch from the lower case face. Neither of my pullers will fit in there, and if I grind the jaws down to fit in, I have no confidence that they won't break.
I could grind the shaft off the crank, (which, BTW, isn't hardened and is NLA), but I can't reach the upper end, even with a small die grinder wheel. The best I could do it get to within 0.5-inch of the top and then I'd still have a 0.25-inch thick section, 0.5-inch long, to deal with. So far, the Oxy torch has proven useless. I can't pry against the case; it's cast AL (and NLA).
Short of fabricating a means (welded ears) to grab the pulley shaft, I'm at a loss to remove it with the tools at hand.
Any suggestions leading to a removal would be appreciated.
