What brand master did you buy?
No caliper?
This.X2 with pinhead. I've gotten a lot of brand new masters that just don't work right. Start with that. Buy Aisin
or Toyota to be safe
Which rear brakes fo you have? If you have the 1 1/8 double piston ones you have to bleed them either on a bench or with the shoes off.Same problem, except mine is all drum, single stage master cylinder, 1970 FJ40. The brakes have about 14K miles on them. The master, wheel cylinders, shoes, etc. are a Cool Cruiser complete kit which was installed by the mechanic doing so much work on this rig from December 2012 until March 2014 when we finally got it registered. But......the brakes have ALWAYS required pumping to get good stopping action. Recently I moved many new parts from my '70 to my '79. With it done and working I wanted to move my $1,000 worth of brake stuff over. I took the right front off of the '79, then did the same to the '70. Oops, the '79 has FJ45 front brakes, lines are different, drums are larger, shoes are wider. So I put the right front back on both vehicles. On the '79 I followed a tip I found here on Mud about adjusting the shoes up tight on the drum before bleeding. I then used my Mity-Vac without success. So I used the jar with a hose approach. The same tip for adjusting the shoes spoke about immersing the hose into the fluid in the jar and cracking the bleeder and then slowly pumping the brakes and then tightening the bleeder screw. This worked fine, good brakes. So now the '70 is back together but of course I need to bleed the brakes since I had the right front cylinders off. Such fun trying to adjust the front shoe on the front side of an FJ40. It just flat sucks. The only way I can find to do it is to remove the drum and adjust the front shoe until you can just get the drum back on, which isn't as close to the drum as one really wants that shoe. So I crack all eight bleeders and slowly pump the pedal and put a stick between the tool box and pedal to keep it from coming up and sucking air. This of course allows brake fluid to dribble down the inside of the tire, but it gets fluid moving through the bleeders. Then I close them up and start at the right rear. After going around twice I found that I still had some bubbles at the right rear. So I decided to use two hoses and one jar and went around twice again. Of course anytime you move from one wheel to the next you now have air in the bleeder hose so as soon as you crack the bleeder under pressure you are going to get bubbles as the fluid pushes through the line. So by slowly pumping the pedal and then holding it down with a stick (the pedal will of course come up some because of the length of the stick, but not all the way up) I move about half a master cylinder of fluid through the lines. But, there is always the "but", when I'm done the pedal will push nearly to the floor, two pumps and it is hard as a rock. If air in the lines is spongy, why do I have to pump to get a hard pedal?
