Vae Victus
Posting more than I know
Is that a plastic part? With dimensions looks like a good candidate for a 3D printed replica. (Says a guy building a Voron 3D printer).Horn spacer, #4
Everybody needs at least one, I need two.
Ok. I get it. I'm familiar with the setup. Is it the same for all years? I don't recall if they are.This (part #4) just separates #3 from #5 until #1 is pressed at the edges and flexes #3 to make contact with #5.
Omaha!
Electrically neutral is only real requirement. Then maybe whatever would last longer in an increasing ozone environment . Thickness is semi-critical, that’s the issue with SORs (even after it’s trimmed) as #1 has to be aggressively/completely flexed to get #3 to bend enough to contact #5.
Hut. Hut.
I used the Parts form (gazoo)and entered all the numbers I had for the limited listings(the form would not let me continue--asking for the part numbers(which I had provided) I even tried one number(a head gasket) which I just ordered from Toy So. Atlanta(which I have) even that 'new' part number wouldn't work--In January 2020, Toyota began the Heritage Program to begin production of no longer available parts for the A70 and A80 Supra. In July 2020, Toyota added the 2000GT to the list of vehicles with parts production support through the Heritage Program.
Earlier today I made my frequent parts order call to my local dealership to get the common response, "part # XXXXX-XXXXX that you want to purchase is NLA". I'm a resourceful guy just like everyone on this site and I can do a lot to revive old worn bits but there is a limit to what can be rebuilt. Scouring fleabay for sketchy used parts isn't my idea of a fun afternoon; I'd rather be opening a Lexus/Toyota Genuine Parts box and installing a new part into my old cruiser. Why is Toyota supporting the Supra and 2000GT and not their most iconic/flagship vehicle, the vehicle that enabled them to enter new markets around the world and was largely responsible for the success of their company?
So I called Toyota's customer service at 800-331-4331 and spoke with Carrie W. (she's awesome BTW). I pitched this request and ended up on hold while she talked with a supervisor. She came back and said the supervisor response to my question was that they haven't had any significant volume of inquiry requests for adding the FJ25 or FJ40 to the Heritage Program, but they would send the program managers my request and... if they found there was enough demand they would likely add support for these vehicles. If you'd like to have access to new OEM parts that are currently NLA then please call the number and person listed above and put in a request. We may be able to get the Land Cruiser added to the Heritage Program if we flood them with requests. I may call them once every day until they get so fed up with me that they just do what I'm asking.
Also, my daily NLA parts order was: 17343-61020 hose between air bypass valve and check valve, 17342-61030 hose between smog pump and air bypass valve, 19220-61102 distributor vacuum advance (dual diaphragm style), 17810-61010 distributor air filter, at this point I gave up and ordered an air filter.
1977 BJ40 in Costa RicaWho else is going to buy enough parts to build a spare FJ40 from scratch?
Even if the parts are expensive, I hope enough people buy to show interest in the program.
