Yeah I kinda feel like they're under estimating the 40 series parts demand. I hope us little people will get to partake.
Are they going to use the old part numbers for the new production of parts ? And where do you order from?
I want to replace both exhaust pipes front and middle .
Wouldn't' these people need access to all the proprietary drawings, assembly and testing instructions ? Would Toyota even have these and/or their vendors, if they still exist ?
If people contacted them trying to just get product history like how many FJ45s were imported, and were unsuccessful, I sincerely doubt contacting them about more detailed part information would be high on their list. Now, reproduction of parts without all of that will work as it has been for a lot of parts.Contact Toyota and ask them.![]()
I nominate CruiserdanOn their website they state they will be asking members of Landcruiser interest groups for input. Geez Louise! You think someone from Mud would have been tapped for that honor.
Yeah, he was a given member of the initial survey group.I nominate Cruiserdan
Yeah but do we need exact part #'s or will descriptions work?Click the link and there is a link in the announcement to take a survey for parts wanted.
i got me someSoft-top doors quick hinges would be cool =)
| Item | Part Order Timelines | Part Shipment Timelines (In the case of USA) |
| License plate lamp | Jun. 2022 or later | Aug. 2022 or later |
| Front turn signal lamp | Jun. 2022 or later | Aug. 2022 or later |
| Control knob | Jun. 2022 or later | Aug. 2022 or later |
| Starter | Jun. 2022 or later | Aug. 2022 or later |
| Starter brush holder | Jun. 2022 or later | Aug. 2022 or later |
| Magnet starter switch | Jun. 2022 or later | Aug. 2022 or later |
| Light control switch knob | Jun. 2022 or later | Aug. 2022 or later |
| Back up lamp switch | Jun. 2022 or later | Aug. 2022 or later |
| Transfer indicator switch | Jun. 2022 or later | Aug. 2022 or later |
| Transfer output shaft companion flange | May. 2022 or later | Jul. 2022 or later |
| Parking brake cable | Jun. 2022 or later | Aug. 2022 or later |
| Accelerometer wire | Jun. 2022 or later | Aug. 2022 or later |
| Front brake tube | Jun. 2022 or later | Aug. 2022 or later |
| Rear brake tube | Jun. 2022 or later | Aug. 2022 or later |
| Combination lamp bracket | May. 2022 or later | Jul. 2022 or later |
| Shift lever spring seat | Jun. 2022 or later | Aug. 2022 or later |
| Shift lever spring seat cap | Jun. 2022 or later | Aug. 2022 or later |
| Meter dropper | Jun. 2022 or later | Aug. 2022 or later |
| Windshield weather strip | Jun. 2022 or later | Aug. 2022 or later |
| Front drive dust cover | Jun. 2022 or later | Aug. 2022 or later |
| Brake master cylinder | Jun. 2022 or later | Aug. 2022 or later |
| Disc brake cylinder | Jun. 2022 or later | Aug. 2022 or later |
| Rear wheel brake cylinder | Jun. 2022 or later | Aug. 2022 or later |
| Steering relay rod | Jun. 2022 or later | Aug. 2022 or later |
| Front exhaust pipe | Jul. 2022 or later | Sep. 2022 or later |
| Center exhaust pipe | Jul. 2022 or later | Sep. 2022 or later |
| Vane pump | Jul. 2022 or later | Sep. 2022 or later |
| Intake valve | Jul. 2022 or later | Sep. 2022 or later |
| Exhaust valve | Jul. 2022 or later | Sep. 2022 or later |
| Vane pump pulley | Nov. 2022 or later | Jan. 2023 or late |
Need that Brake Master Cylinder! does Dibs work???■LAND CRUISER 40
Item Part Order Timelines Part Shipment Timelines
(In the case of USA)License plate lamp Jun. 2022 or later Aug. 2022 or later Front turn signal lamp Jun. 2022 or later Aug. 2022 or later Control knob Jun. 2022 or later Aug. 2022 or later Starter Jun. 2022 or later Aug. 2022 or later Starter brush holder Jun. 2022 or later Aug. 2022 or later Magnet starter switch Jun. 2022 or later Aug. 2022 or later Light control switch knob Jun. 2022 or later Aug. 2022 or later Back up lamp switch Jun. 2022 or later Aug. 2022 or later Transfer indicator switch Jun. 2022 or later Aug. 2022 or later Transfer output shaft companion flange May. 2022 or later Jul. 2022 or later Parking brake cable Jun. 2022 or later Aug. 2022 or later Accelerometer wire Jun. 2022 or later Aug. 2022 or later Front brake tube Jun. 2022 or later Aug. 2022 or later Rear brake tube Jun. 2022 or later Aug. 2022 or later Combination lamp bracket May. 2022 or later Jul. 2022 or later Shift lever spring seat Jun. 2022 or later Aug. 2022 or later Shift lever spring seat cap Jun. 2022 or later Aug. 2022 or later Meter dropper Jun. 2022 or later Aug. 2022 or later Windshield weather strip Jun. 2022 or later Aug. 2022 or later Front drive dust cover Jun. 2022 or later Aug. 2022 or later Brake master cylinder Jun. 2022 or later Aug. 2022 or later Disc brake cylinder Jun. 2022 or later Aug. 2022 or later Rear wheel brake cylinder Jun. 2022 or later Aug. 2022 or later Steering relay rod Jun. 2022 or later Aug. 2022 or later Front exhaust pipe Jul. 2022 or later Sep. 2022 or later Center exhaust pipe Jul. 2022 or later Sep. 2022 or later Vane pump Jul. 2022 or later Sep. 2022 or later Intake valve Jul. 2022 or later Sep. 2022 or later Exhaust valve Jul. 2022 or later Sep. 2022 or later Vane pump pulley Nov. 2022 or later Jan. 2023 or late
