Hey i have a fj40 with 10" wide rims running 33x12.50 15" the tie rod ends are rubbing on the inside of the rims does anyone know what can be done other than putting spacers on it Thanks.
Not sure what you mean.Unsrew the steering stop
Will not help this problem at all.Unsrew the steering stop
Thats what I thought, but i was hoping maybe they had different tie rods that would clear allow it to clear. Thank you.Will not help this problem at all.
Only solution is spacers or different rims.
How to contact this “Luke”? I’m in need of a proper steering arm for my spring over.
How bad is the rub ? Mine used to just barely rub the boot and after awhile it would wear a cut in the boot. I ran it like that and liked it cause if the steering arms get loose you can hear and feel the tie rod end dragging on the rim. New boots every once in awhile does not hurt anyway. I eventually put 1/4 inch spacers on. FWIW the 1/4 spacers reduce the amount of thread engagement on the lug studs so if you have anything besides a steel wheel it may reguire longer wheel studs pressed into hub to run an aluminum wheel.
