Aftermarket damper is different and is normaly use with saginaw PS conversion
Never underestimate the PO's ability to screw up your '40. Take tons of photos for the before and after comparison. Use the FSM and search here to ensure that you are reassembling correctly and to spec.My lord still finding things out that my PO or PO’s mechanic did crazy
You're dampener is aftermarket. A stk dampener uses the hole in the center arm and attaches to the frames crossmember. You can see it in @lowenbrau 's post #7.
I have a Toyota Tercel power steering conversion again from POAftermarket damper is different and is normaly use with saginaw PS conversion
I wanted something silver to match my Bill Stein 5150s. I can’t use bright yellow. Id just kill myself.Never underestimate the PO's ability to screw up your '40. Take tons of photos for the before and after comparison. Use the FSM and search here to ensure that you are reassembling correctly and to spec.
I'd suggest getting the right steering damper for your vehicle. This one worked great for me and is a complete kit from @cruiseroutfit
OME Steering Damper - Fits 40/45/55 Applications (OME SD23)
OME Steering Damper For Toyota Land Cruisercruiserteq.com
There are others from other vendors available. I did not see what year your chassis was.
The dampener you bought will work. You just need to mount the end that attaches to the tie rod so it doesn't interfere with the tie rods travel. Make sure the U bolts are tight so they don't slip.
