I went from 80lbs corner to 93lbs on my setup now, i didn't notice much in terms of acceleration, but braking wise you can feel you need more distance to bring it to a stop. Also my gas mileage took a 1.5MPG hit, worth the trouble tho i'd say.
I'm all about the weight... in my other car. I think you'd struggle to notice 80 vs 95 per corner in a 100. I say get what you want, regardless of weight. It's a bus with oem wheels/tires so you have little to lose.
I do love how the tires fill out that well in low. Essentially tucked. I think the view in low is more impressive than a lift, haha.
That's true. However... those components all last something like 200k miles under normal OEM circumstances. Even if I cut that life by a factor of 50%+, totally worth it in my book. It's a beast of a vehicle. Abuse it how you want and just pay that tax to the car gods as it comes due. Still probably leaves you with longer maintenance intervals than most any other vehicle outside the Land Cruiser family.I hear that. I'm more concerned about longevity than performance in this application though. If the stock wheel/tire comes in at 70lbs, 95lbs is about 35% more weight. The suspension components have to control that extra weight and IMO that's a lot to ask from the bushings, shocks/AHC, etc.
Haha, you know it's funny. Dissent actually reached out to me based on an instagram photo I posted telling me about how easy it was to relocate that bracket right by the washer bottle, as though it was a given that it was a problem (aesthetic or functional).Truck looks great for sure. 34.5" is the sweet spot in tire size IMO. Although how on the earth yours are not kissing the washer bottle is a mystery to me. Mine would hit, even if turn too sharp to the right causing the left front to compress!
So far, no contact I've seen, but I haven't looked at that specifically. Might squeeze in a couple more trails this year, but so far it's been all good on the few I've done!
When I bought the car the po had a denso fuel pump that he included in the sale. I installed that last year. The car has had weak warm starts since I bought it and installing the denso pump did not change anything.Let me know if I can help Andy?
Some feel all 100 series boil fuel. This is simply not true.
Fuel boiling to point of vapors coming from gas cap. May indicate EVAP damage issue.
1) Could have been from current or prior engine running hot.
2) Fuel tank overfilled (squeeze gas pump nozzle handle, after auto shut-off) at any point in history.
3) Age related.
Those are just a few of the causes/reasons
Also take note the 06/07 have weak fuel pumps, best to R&R as a PM over 150K miles. Typical sign is engine dies once fuel hot, like after running at higher RPMs (fuel pump runs in high speed). Weak fuel pump can starve engine of fuel (run lean), which cause cylinder head temp to climb.
I've noticed fuel vapor collecting just under the fuel door on my 05 LX.Update: Failed to start when hot!
Well frustrating development yesterday. Spent an hour or so driving around town looking at potential future home-buying regions of the Outer suburbs of Denver Metro. Stopped at a gas station. Turned off the car while wife and child went in for the restroom. Ten minutes later I go to fire it up and it stumbles for a few seconds and dies. Strange. Start again, dies even faster. Uh-oh.
Cranked it many more times trying a combo of holding gas pedal down, not, letting it rest for a few minutes, etc... Nothing worked. After around 10 seconds of combined cranking, it would go from slight stumble to absolutely zero stumble and just smooth cranking as though there were no fuel at all. It was only 75F outside so not screaming hot. Coolant temp was 185F and intake temp was ~160F (indicating engine bay was real hot).
The fix: I opened the hood for about 10 minutes, cracked open the fuel filter line, let about a teaspoon of liquid fuel out and re-tightened. Then tried starting again. First try stumbled and died, but the next one took. I revved to about 2500 and slowly let it come back down to idle. Drove perfectly fine the rest of the day and I couldn't replicate the problem when I tried.
Additional notes: I could see fuel vapor pouring from the gas tank filler area in my rear view mirror. There was no pressure in the tank when I vented the gas cap. Seems the tank was just evaporating a ton of fuel.
Conclusion: Fuel rail boiled the fuel and took time to cool down. Cracking the fuel line probably vented some vapor, but also dropped pressure quickly and therefore lowered temp (perhaps negligible?).
Assumed Cause: Fuel too hot in the rail.
Next Steps: inspired by J1000's work, I bought a fuel temp sensor a while back. I'll see where I can plumb that in and get some temp baselines. He found an array of fixes that together brought his temps down. I'd like to do something similar, but more targeted. I've got a thermal camera and a lift. My plan is to get the fuel sensor hooked up as close to the rail as possible and see what situations yield the highest temps. It seems to be sitting after long idles. Then I'll use the thermal camera to hunt the hot spots. The goal being to do one single thing to dramatically improve temps.
Anyways, there ya go. Failed to start for the first time in this 06. My wife is not pleased, haha.
Updates:
1. Replaced the FPR. No improvement. Still starts rough when warm. I seem to not have any time to do anything fun with my car lately, but I'd still like to plumb in some test equipment to figure out how to most directly address that.
2. Ridge Grapplers are not good snow tires in very cold temps. We got our first snow/hard freeze and I was setting off ATRAC when setting off from every stop light with just a feather of throttle. Got a little side action on a very modest bend on the highway. Worse than KO2. Not even comparable to dedicated snows like I ran on my 99. I'll probably be picking up a pair of dedicated snows for next season for the factory 18" wheels.
3. Wireless Android Auto on the Grom VL2 is great. Works very well with the one exception that phone calls are often completely dysfunctional. Incoming calls answered through AA silence the incoming caller while the mic still works. Frustrating.
I recently switched from KO2s to Falken WildPeaks and have been impressed with their snow/cold weather performance - way better than my old KO2s anyway. We've had a significant dump in the PNW and they have been solid on greasy side streets and highway trips to Whistler. Appreciate they are not dedicated snow boots like the Blizzaks but sharing my .02 for what it is worth.Hopefully you'll figure out the rough running issue soon.
I am finding Ridge Grapplers to be inadequate in single digit weather and icy conditions too! I wish I could find some Nokians in 33" size, but it is increasingly looking like I will have to settle for the Blizzaks
275/70/r18 (33s) Nokians are one of the most widely available sizes that they make. I run the Studded Hakk LT3 in that size on my LX470 and my 200 series up in Montana.Hopefully you'll figure out the rough running issue soon.
