LAMBCRUSHER
Also, verify the sniper is reading Chinese correct like. Measure volts at battery when sniper say you’re high
Ah, thank you for clarifying!
I think you will have to trace wiring to be sure. Either trace from alternator to regulator, or trace harness from mystery box.
Do you have Pig wiring diagram to trace wire colors?
This little guy is on the drivers fender and I just noticed it was unplugged. I’m guessing this is it.
Crusty old box is horn relay thinks me
You can read HORN RELAY at the top of the crusty bucket, or is it just me?
What alt are you running?
Wgnrog did you replace the regulator because things werent working correctly like when I have my lights on and am running the fan, go to signal a left/right turn my turn signal says on. When I rev the motor it starts blinking again.
Did you replace because you were having these problems?
How was the cabin noise after the sound deadening work?
So bucket swap too... Guess the 5spd pushed too far back to work with the bench, or just wanted something other than the bench?
