That motor was toast. So many thing going on once we pulled the oil pan. Huge amounts of what looked to be carbon in the pan. That or a sealant material that had been hardened. Then I notice the cam. Toast. Pitted and worn to one side. Was a sign of thing to come. Juice pulled the valve cover and he yanked the rockers. ANother issue. Both #6 connecting rods were of the newer style. (smaller diameter). Not a huge deal but if your rebuilding the top end right why not put the right connect rods in that match all the rest? WIll beinteresting to see what #6 piston and valves look like. AT this point I told him we could button it all back up and just run it until it blows. Not someing Juice wanted to do. SO we took the timing cover off. And there was the issue. No c'clip on the camshaft. Cam gear had been walking around the cam for god knows how long. Looks like the clip was nowhere to be found. Also the cam gear looked like it had been installed with a sledge hammer. It was all beat up. Why anyone would get this far into an engine rebuild and cheap out on this is beyond me. Sad because I'm sure some of the PO's had no idea they had a ticking timebomb on their hands. So we yanked the cam and inspected the bearings. Toast. All but one was worn or missing chunks. The cam was junk. Would have to have every lobe fixed and that is not cheap. A new one as well as a new cam gear is in order. The we noticed the cam plug. It poped out with my finger. At this point we new it was going to need a complete rebuild. Head will be coming off. Sorry Juice for all the problems.
Wow, good amount of work done there. Good for you. Sorry to hear that it's going to be a bigger job than originally planned. Cam looks bad, but i've seen them with an entire lobe worn off, so it could be worse.
If I were you, I'd look at new lifters as well, especially since you're putting a new cam in it. By the time you pay to have those machined (I wouldn't run them on the new cam as is), you could probably buy some new ones.
Since I can't remember the compression numbers, if they were good, I'd probably leave the pistons, cylinders, and head alone and do the mild rebuild. Otherwise, have the cylinders checked for round and look at valve job on the head. Are you going to pull the pistons? Was there any blowby before?
Good luck, Juice, and if you want a hand, let me know.
I was thinking of a hone and new set of rings. Might as well since the machine shop is going to have to replace the cam bearings.
Holy Crap!![]()
That engine was rebuilt by a Toyota dealership in Washington one or two PO's before TJK. They also rebuilt the transmission and transfer I think. You might want to inspect those, at least drop the tranny pan and split the case.![]()
Carbon on pistons is normal in a carbon-fueled engine.[FONT="]I believe this was about the time Trollhole left and gave me some homework to finish.
Rotated the motor back over and pulled the head. Headgasket looked good. (Sorry, no pic.) I took some pics of the underside of the head. I don't plan on doing any work to the head besides a new gasket.
Valve 2.
Valve 3.
Valve 4.
Now I could look down into my cylinders and at the top of my pistons. There was what I thought to be some major carbon build-up on tops of several of the pistons. Should I be worried about this?
The pics of the valves above are butchery. Note how the incompetent previous repair was unable to achieve the proper press fit of the exhaust valve seats, so a punch was used to peen the casting around the seat and (hopefully) retain the valve seat more securely.
This is very bad. Valve seats that break up while the engine is running can cause catastrophic engine failure.
