I spent some time this weekend stripping down the donor 2F. I talked to Trollhole this weekend after I helped pull his 2F and was waffling (or some call it 'flip-flopping') on if I should install the donor 2F with my desmoged equipment, fix my current 2F the reinstall, or if I should just fix my current 2F and sell the donor 2F. So, under direction of the great Troll I ran some compression numbers on the donor 2F.
1 - 155
2 - 145
3 - 152
4 - 146
5 - 150
6 - 148
On the donor 2F (comp #'s above) mileage is unknown. I still need to run compression numbers on my original 2F.
I was told to make sure the carb was fully open. I had not removed the carb but I think it was open. Take a look below at a pic of how my carb sat when I ran my compression test. Is this 'open?'
Open the throttle all the way and insert a long screwdriver.
wanted to take the boys (read: dogs) for a walk so I had to call it an evening. I can't do a whole lot more on the donor 2F until I get use of an engine hoist again. I'm going to strip off a few more parts to get some stuff out of the way and then wait. Once I get use of a hoist again I'll throw the donor 2F on a stand, spin it upside down and pull the pan to see whats up in the lower end. I think the lower end will be worse than the upper end.
