Terrain Tamer parabolics installed (5 Viewers)
@BullHab 😳 your 5 years younger I should be following you…🤞
I think the one thing I could have as an advantage is that all of this was just removed in June so, since it is all so fresh im expecting basically factory torque without the impedance of years of bonding and other materials providing additional security against removal
So, for those who have installed these spring sets….where would you say the greatest amount of muscle is required? I lack much of what I had and while I have done my 40 springs but it was 1976…
Working smart is always the solution. Using leverage and well placed blocks of wood. The largest true ‘lift’ is probably moving the springs from the front porch to under the rig, and carting off the old springs. Everything else can be aided by having two floor jacks, jack stands, and 2x4 and 4x4 wood scraps. Using leverage to get the fixed spring end lined up and installed, floor jack to lift dynamic end up and install the shackle. Floor jacks to lower the axle housing back down.
For me, hardest part is often the tightness of the polyurethane spring bushings. Using clamps to pull / push spring pins through, with hammer persuasion as needed. I went back to oem rubber bushings this last round. Rubber fit like a glove on my TT parabolics and installed so easily.
@BullHab I had decided not to update my springs under a recent series of big upgrades. Questioning the wisdom of that decision since I am driving it so much more. I will be looking forward to your review among the many I have read so far. I am not a rock crawler but I live on a long dirt road and enjoy riding a few fire trails around here. Some of the potholes are not even a bounce but a hit and you feel it. I might describe it like a high end turntable that has locking screws used for shipping but…you remove them when your playing records and the spring action is restored…My truck feels like they never removed the shipping screws . I dont recall any of my other Fj40’s riding like this
My dirt road is jarring enough that the reality of a smoother bounce is starting to gain popularity in my head again. Just getting the mail each day can be an adventure …imagine that?
I agree completely. I put Saginaw steering and a shackle reversal kit on "LUCY " this Sping. What a great refinement!! Hopefully this kit will smooth out my stock springs. Later i plan on a five speed and fuel injection.
I can speak to the fuel injection….spectacular!!… I wanted to go 5 speed but a discussion from @wngrog convinced me to get 2 front 3.70 geared differentials and make that swap. My FJ40 has a completely new attraction. I am probably 20% down in 4th for engine rpm. Using an iPhone gps speedometer app it was running 83mph with a fair amount to go. I am so sure it would make 90… not what it was made to do but it does demonstrate the changes with gearing and good fuel input.
THIS is what dictates the purchase of the Terrain Tamer spring kit… I am old enough that the hard bounces of a dirt trail fatigue me a bit and the theory is, these spring help to improve that… I held off a long long time..truly believing this would not really be much of a change but after a year, I really do hear otherwise…we’ll see soon. There on their way. Probably be here mid week
Al- with the terrain tamer springs, the next set of tires can be 33” for even better hwy rpms.
Funny but I find my self in 3rd …lugging around some corners…big difference with the gears
You’ve done a freakin’ great job Jesse @Jdc1
Another question for Jonathan or anyone else using the Koni Raid shocks. The O.D listed for the Koni's are 2.7". How is this with the drag link? I have Bilstein 5100's currently, which are just under 2" and it's a tight fit. Also, there are a few part #'s out there for the Koni's 40 series. If anyone could confirm these that would be helpful. l
Thanks
Wow, I sort of missed this! If it's still of use, Koni does not make a Raid shock for the FJ40. Mine are Koni Heavy Tracks, and there is no clearance issue with the drag link. I love the Konis, but the parabolics on our Troopy ride on Terrain Tamer's own shocks, and they are excellent.
I appreciate your input. I hopefully get the suspension kit installed in the next week or two. I'll swap the fuel injection up my wish list over the five speed. Another friend of mine suggested to swap my 33 inch tires for 35's, kind of a "rubber overdrive".
Thanks again and I'll be waiting for your updates.
35 are too big for this lift kit
At 5’11” …173 lbs and 72 1/2, (yes the half matters) I can’t just step on the running board and walk in- if it weren’t for the steering wheel I would need a step stool. I am looking at 33’s I have seen on Mule 2.0 and @Jdc1 ‘72 FJ40. Those bigger sidewalls get me
My arms are like Olive Oyl…not Popeyes’
Look at actual diameters- BFG are pretty small 33s. An extra 3/4” might be noticeable.
My arms are like Olive Oyl…not Popeyes’View attachment 3979152
I’m really looking forward to seeing the Terrain Tamer springs on the road. The shackle angle keeps getting better…
@Jdc1 Man, I love those tires… I was thinking “ they gotta be noisy”. But …the interior noise at speed is pretty darn loud to begin with
Is that terrain tamer on this 40?
Ps…. I still love that yellow one
Al- We’ve got 1k miles on the 72 w/ km3 and don’t notice too much tire noise.
The 71 pictured above has TT springs.
The Mustard ‘75 ‘s owner was at his wits end with steering and stopping(lack of). FJ60 disc conversion and EPS fixed it right up. He’s now desmogged and has a Jim C carb.
In some of the FJ40 installs it looks like the rear axle is moved forward. Any idea how much? I’ve already got a pretty short driveshaft (or so my wife says) from Tom Woods so moving the axle forward is a no go. Looks like a great product though.
Easily solved by redrilling the spring perches and u-bolt plates. Worth the effort for better aesthetics of a wheel well centered rear axle.
@EWheeler ..As easily as I think I see what your saying, can you describe this to clarify it in my head… my pallet is arriving today with the spring kit and I am going to assess whether or not I do need any positional mod.
In my head (and much of it is filled with other useless junk) the axle goes where the spring pin lines up. How is it relocating by drilling?
Or am I thinking ofo the spring hangers? Sorry for my confusion
