JohnnyC
Long ago TLCA# 2231
Please update when fixed !
what a complete lack of competency on the shops part.
I know you did not want to mention the name of the outfit......but it might be a good time, save others the experience you have had
Need pictures of the shackle and spring bushings.
I would rebuild the knuckles,
check the length of ALL rods
If you have not already, throw that damn steering stabilizer away!
Isolate each joint and check for slop
Check the bushings
Center everything according to FSM
Check this centering process again.
Reassemble
Do the push pin alignment
With wheels on the ground, turn wheel and watch your spring eye bushings, and the u bolt plates at axles.
It is a system, and somewhere in there is a weak link. If you go through it from top to bottom, instead of letting someone else skip around, you will find the weak link. When properly put together, it will work properly. It has no choice!
In a shop like yours this should not take a day. Throwing on a new suspension is not going to fix your steering issue. It is a steering issue. If you do not want to do all of this, bring it to WNC and leave it for a few weeks.
Not trying to be cutting, just straight forward.
Frank
I didn’t read the whole thread, but if the truck wanders and the steering wheel does not self center after turns, there is a caster problem. Try a 2 degree caster shim between the spring and perch with the fat end facing the shackle.
The closest to you, who I KNOW knows what he is doing is Marshall at Trollhole. Vendor on here. He is in the Greenville Spartinburg area. Talk to him. Sounds like you need to put it on a rollback and send it somewhere.
Frank
An alignment shop that does trucks with solid front axles can do it. The stock manual steering gets +1 degree, but with power steering more like +2 degrees would give more self centering force. Zero caster is the magic angle for wandering and no self centering, so I predict you are close to zero. This is a little odd for stock springs and shackles, but not unheard of. I probably did a thousand alignments back when I was turning wrenches for a living, so I have some experience with this.
