So how fat is it?
you didnt see the scale pic in the last post? It was 7440 with 2 of us and whatever we had left in the truck.So how fat is it?
Thanks for cooking such good eats on the trail. Wow, your junk weighs a lot.you didnt see the scale pic in the last post? It was 7440 with 2 of us and whatever we had left in the truck.
thanks for noticing my junkThanks for cooking such good eats on the trail. Wow, your junk weighs a lot.
Hey, hey. Whatever happened out there between you two should stay out there. This is a family site.thanks for noticing my junk![]()
It’s not like that.... however, he found out that bigger tires are not always the answer.Hey, hey. Whatever happened out there between you two should stay out there. This is a family site.
Just incase you forget your shades, there is a dimmer switch on the dash - it is easy to forget it is there - not sure it works with LEDs though.Of course. You're driving a cruiser so you got to have your shades on 100% of the time. You must have not read the owners manual. How else you going to see the cluster if it's dim with 30 year old bulbs!![]()
Sounds like just what you'd say if it was like that...It’s not like that....
Ok that’s funny. Referencing good eats and laughter now encourages images of boy bands and slightness of masculinity? I think I like you.
Bigger tires are always the answer. When have you ever heard anyone say smaller is better?It’s not like that.... however, he found out that bigger tires are not always the answer.
Haha. Yes dimmer works with Leds. I do not wear shades at night like an idiotJust incase you forget your shades, there is a dimmer switch on the dash - it is easy to forget it is there - not sure it works with LEDs though.
Going down to 4 will reduce my up travel and I might have to change my bump stops again. For now I'm using factory bumps + 2 sets of 2" bump stop blocks + an extra half inch on aluminum i put in between to give me a 5" up travel. I had an extra 2" block from my Turbo80 that went off when the Timbren's went on that.Great posts & looks like you learned a lot & going the right direction of lower COG.
39s on a 4" lift will be interesting with how much up travel you will end up with.
I believe Broski is at 3.5" lift now.
Did all the previous fender trimming work out or is there more to do?
What bump stops do you have now?
You shouldn’t have to change the bump stop extensions. You well lose up travel.Going down to 4 will reduce my up travel and I might have to change my bump stops again. For now I'm using factory bumps + 2 sets of 2" bump stop blocks + an extra half inch on aluminum i put in between to give me a 5" up travel. I had an extra 2" block from my Turbo80 that went off when the Timbren's went on that.
All the trimming has worked great so far. I have not rubbed the rear wells at all during the con. I only rubbed front passenger once and it was the front side of the well next to the bumper. Will trim that down in the next 2 weeks.
yes running 4.5" right now to limit up and hitting the rear fender wells. going to try 4" or go back to 2.5"You shouldn’t have to change the bump stop extensions. You well lose up travel.
so you are running 41/2” of bump stop extensions?
