- Thread starter
- #701
I took delivery of a beautiful set of RCV 4340M (300m) two piece rear axle shafts to replace the Nitro’s. I don’t want to spend much time berating the Nitro shafts but, I’ve broken two right rear Nitro’s in a span of five years. My experience is that they don’t stand up well to a heavy truck that’s being forced over buggy lines wearing 37” tires. See the photo of one each broken shaft and one each rather twisted shaft. The fracture happened right where the splines terminate.
The splined end that remained in the ARB carrier wouldn’t come out with a magnet and I knew it was too long to allow me to remove the third member and I wanted to avoid chopping a hole in the axle house like others have had to do when a shaft brakes in an oem locker.
After some thinking and looking into the axle housing from the drivers end I decided to try and snake a 1/4” dia steel rod past the carrier center pin in order to drive the axle piece from the carrier on the passenger side. I’m happy to report that this approach did work.
With the chunk of axle laying in the housing the job became a simple matter of removing the third member for inspection and housing clean out and then reassembly.
The third member checked out ok and now it’s going back together. For the past week I’ve debated whether I’d use the axle shaft oil seal and grease the wheel bearing per FSM procedure or leave the oil seal out and let gear oil lube the wheel bearings. My right rear has been running in gear oil since 2017 when I broke the first Nitro and the seal sustained some damage. The left side seal was still doing its job since 2016 allowing no oil into the hub. The right side wheel bearings and spindle looked like new when I took the axle apart. The left side showed minor signs of contamination and corrosion. I decided to follow the manual and install new oil seals in the end of the spindles even though they are notorious for failing and letting oil in anyway. This way I can at least try to avoid ever dealing with a gear oil leak from the large seal behind the inner wheel bearing. That would cause a mess and possibly ruin the brake pads. If anyone can tell me of positive long term,
no leak, experience running no oil seal and lubing wheel bearings in their 80 with gear oil I’m listening.
