Or you can order new from Toyota.
IMHO, LSD axles are a waste of time. Do the lockers and be done with them.
Agree. Same diff that I currently run, minus the c-clips. I even have an extra FJ62 diff sitting the garage ready for an ARB.
That parking brake seems more like a line lock, which makes me a little nervous. Just don't want a rear brake line bursting.
I'm sure I'll find something.
Brake line bursting shouldn't happen. Do they happen when you step on the brakes? No. So, they shouldn't burst when you apply the line lock.
here's a possibility...
is that the 2F thingy I've been hearing about?![]()
Well I do have that 2F just sitting there, just have it tuck and roll out the back.![]()
While thinking on this project and my axles to be more specific I was thinking a little armor on them wouldn't be a horrible idea. I know I had to do some grinding just to drain my front diff. Thoughts?
i would say sky is the limit. my 80 series stock just has the ring welded to the housing around the drain plug. i put in the allen key head plugs and have messed up that ring some on some rocks, but the plug is unscathed and easy to take out still. i sure you could dream up other skids and such to weld on before you powdercoat the whole housing![]()
For the front of the diff housing, a 8" or 10" fire hydrant pipe cap welded on would be a good skid plate. They're typically about 1/4" thick and strong as all get out. There should be some threads about this mod in the 80 section.
If you have the axle out and easy to weld then weld on a ring around the drain plug like the 80's come with but make it a deeper one, about 5/16" high should be just about the right amount of overkill.
Also for the people running OBA where is your regulator sitting and why? I am thinking my sliders will be my tanks, but have them plumbed independent of each other just in case one of them has a failure.
my OBA is dual mv50's in the aux batt tray for right now. i am running DOT air brake hose for all my lines, 1/4" to sliders and pumps, 3/8" to couplers. i use my sliders for small tanks (i get 3.5ish gal if i recall). i have put a coupler on the front and rear bumper and override all electrics (global on/off) with a switch in the dash. the air manifold is mounted to the back of that box. i have a check valve between each compressor and the manifold. the manifold has my pressure switch and blowoff valve along with all individual component connections (ie 6 individual lines). i can remove and plug any one of the lines if i have problems) i do not run a regulator, the pressure switch is 70-100psi and my BOV is 125psi, i could have run lower BOV but i thought i was going to get a diff pressure switch. all of this will stay intact when i move to York someday (i now have one sitting in the garage). just move the power wires to the clutch and the pressure lines to the output (and i'll get to remove relays etc).
hth
Check your volume for your OBA compared to your tires because after that's gone you're back to whatever your compressor can put out. A lot of people think they can get a lot more than what's actually in there - you need some really high pressure to get a lot of air, more than most air compressors will put out.
Where did you pick up your parts?
this is very true. my air bottles(about 3 gallons) fill up 3 of my tires and only part of the 4th starting at 2000psi.
