- Joined
- Apr 14, 2004
- Threads
- 1,463
- Messages
- 36,605
- Location
- 818-953-9230
- Website
- www.marksoffroad.net
I need to add this to my to-do list. I haven’t seen anything at the store worth buying, so my current drainage only varies from crap to non-existant.The next box and downspout is located at the main entrance and drains the same section of roof.
The last four are located on the north end and drain two separate roof sections and shed the most water.
The one took a few angles.
All the mounting tabs were broken to allow for any stucco variations. That 17 year old 1800 Ellis saw cuts nice angles.View attachment 3288833
The crazy downspout.View attachment 3288832
Overall shot of the last four.
The tabs were caulked along the top and sides followed by paint to match the house. The rest will be left to Mother Nature to provide a natural rust finish. the boxes and downspouts are slightly gapped from the house to prevent rust staining down the walls. That was the reason for bending the tabs, caulking and painting.
Mild steel? Or stainless? Or...?I get it! The beer can thin materials used normally would be dented from a hummingbird strike not to mention the limited designs found on the boxes. The original quotes from gutter companies were also out of line. It was a fair amount of “tinkering” but in the end the entire project cost $1,200 vs $8,900 from the highest quoted, and look better imo.
Thanks!Mild steel? Or stainless? Or...?
Looks great!
The common materials used for gutters installed by “professionals” are 26ga tin or aluminum. Some will offer real copper but I’ve seen too many messy solder joints to pay that kind of money.
The collector boxes I built are made from 16ga hot rolled sheet. The down spouts are 14ga welded square tubing. The tabs are 1/8” hot rolled as well. Stainless would not provide the natural rust finish I’m chasing, not to mention it would have cost much more than $1,200 and added complexity to the project.
man that is shaping up nice!Shifting gears to tile work.
Thanks again to @65FJ45 for the slate. Oscar @tequila4x4 , it’s finally coming together!![]()
Hope to have the run completed tomorrow.
