First of all "Thank you for having this write up", I just rebuilt my first one.
Got my kit from CDan (Thanks!!).
Second of all, I wanted to add comment when installing the suction port back on, you may have to take out the rubber hose out first, because if not, you're gonna have a hard time putting it back in.
I didn't realize the first time I put it on, it bent the bottom plate because I tighten the screw with the top part not all the way in. It leaks and sucking air inside the pump and making frothy in the reservoir tank.
I took it out again and sure enough, the o-ring is strip. Put new o-ring, took the rubber hose out, bolt it in. Put the hose back in, bleed the line
, start the car, and it's all happy.
Thanks everyone!!!
Thanks everyone!!!
