44412-28160 is actually for a Previa and you use it as a substitute for the hose between the gear and the cooler inlet. There is no substitute for the hose from the cooler to the reservoir.
Anyone used the Gates version of high pressure line
My Gates high pressure is failing after 2 years / 25,000 miles.
Not the bolt connection. Best as I can tell its where the hose is attached to the fittings. I'll clean it up well and then watch it better before I replace it.
Do the bends in the replacement Tacoma hose get in the way of anything or does it just take a slightly different route in the same space as the original hose?
