Builds Patch's Build Thread (4 Viewers)
Was that before installing a front locker?
I don't think that there's too many other people grenading front diffs with lockers installed though, hahaha. Props on that! 🤣
This was also post-locker...
So my kill count is:
1x OEM '99 open 2-pinion (spider blew up) 4.30 - July 2022
1x OEM '98 eaton locked (ring and pinion shredded) 4.30 - April 2023
1x Nitro Gear eaton locked (ring and pinion shredded) 4.30 - November 2024
I'm adding reduction gears to my t-case for high and low range to hopefully reduce wheel spin under acceleration/crawling.
Shock loading seems to do it...
You don't say......
those are numbers to be proud of lol, you need to become a quality control tester for Toyota
Running maintenance/mods checklist:
  • retorque/repack wheel bearings
  • replace LCA bushings SuperPro (again)
  • replace steering rack bushings SuperPro (again)
  • replace rear axle assy.
    • weld on PCK
    • move brakes from old to new axle
  • T-case regear (LR & HR)
  • replace front bump stops with new Perry Parts prototypes
  • mount new tires on wheels
  • balance new tires/wheels
  • clear 37s (BFH?)
    • washer bottle relocation (80 series bottle in AHC reservoir location?)
  • replace outer TREs
  • replace inner TREs
  • spot weld trailing arm nuts
  • remove & sell White Knuckle Sliders (AHC two-leg)
  • install new sliders
  • remove and sell Dissent rear bumper (link to sale thread be posted here)
  • remove sleeping platform
  • install 2nd row seats
  • remove & sell Ironman front bumper
  • weld & install front bumper
  • finish spoiler design
  • remove & sell mountain hatch tailgate cover
  • install GA’s custom tailgate storage setup
  • design & install tailgate reinforcement bracket (for OE tire carrier)
  • remove & ship front diff to ECGS
  • re-install front diff
  • install new diff drop (oops broke it)
  • find & repair AC leak, recharge system
Ever growing…always towards chaos
going high clearance bumpers?
Also 37s!??
After all those CVs already !! (Or so I've read ;) )
Yes- Coastal front and not sure about rear yet...
Also 37s!??
Also yes- I've been of the theory that at some point capability counters fatigue/stress but finding that balance is hard.
Put another way, I wonder how much more stress it requires on the vehicle to climb an obstacle using momentum on 33's that with 35's, per se, may be easier...gears are a must at this point
    • weld on PCK
  • clear 37s (BFH?)
What is this spoiler design you speak of? Are you trying your hand at the Tacti-Tail?
BTW I have the nuts and bolts missing from your tailgate kit. Want me to drop them in the mail to you?
View attachment 3797866View attachment 3797867
I've actually been kicking this idea around in my head for a while now... My LX doesn't have a spoiler of any kind, but something for chase lights would be cool.
G.A. Are you cutting those on your new table?
Bled the brakes, put in a 146,000 mile rear axle, freshly balanced driveshaft, RWD for now. The daily driver tundra’s transmission just took a s*** so looks like the LX will get some use.
I put the 35s back on for now while I’m still making room for the new meats
Somehow the ‘D’ light has returned after four months of no use. I could’ve sworn it wasn’t working- I’m not old yet am I?
Looks like your shop is a paint booth?
