Builds Outsane/Solvefunction/Cruisin2Camp Build (3 Viewers)
January 2023
Newish driveshaft from Nick
The front diff drain plug needed some help
Also welded on a little protection
Air freshner, red button from @NLXTACY
Present day..
Tried rolling fenders with a modified roller.
Started to work then the cat plate broke.
So I picked up a hammer..
And bent in the lip
I think all I need is the lip bent in for the rears to tuck all the way in and max out on the tub.
Since I am not @Wermz or have 40s.
You could be ;)
If you can clear 37s with a lip roll, more power to you. Tire brand, wheel width, offset/back spacing, wheel spacers, bump stop length, all of that plays a roll in where the edge of the tire will impact the body. When i was on 37s i was 100% stock body and suspension, stock 4runner wheels with 40mm spacers, i had to cut the body a lot to clear a 37 in the rear.
You could be ;)
I'll keep trying
It's a bit of an experiment to try and fit 37s with out cutting..
The yokohama x-at 37x12.5x17 don't bulge out luje the falken mt of the same size.
0 offset rims so 4.75 backspacing
About a 2.5 in lift
Dunno if you actually wanted someone to test those rear lower link bushings for you, but I need to change mine again so I'd be willing.
So this happened
Right now it's a very slight leak, gathering parts for hg replacement
Bummer Lee, better that you caught it early !!
Acquiring parts for a headgasket job, spare head is at the machine shop.
Power steering resevoir bracket has been made and fits perfectly. This mounts a chase bays res, psc to come
Went through the driver's rear axle to replace the axle seal and regreased. There was leaking all over the brakes and wheel. I had a hell of a time with the stub nut. Looks like I need a new stub shaft.
I got to use my own gasket!
Feb 2023
Went to Koh helped out Amber turner
Rebuilt the charcoal canister, didn't change much.
New rear bumper from @Delta VS with swing outs is badd ass!
I have switched around parts so many times on the modular bumper. It's been really nice to use the mounts like legos.
March 2023
Rebuilt front axle seal, leaking into the brakes.
Replaced the rear markers with printed parts I can replace for cheap.
Made some valve caps I can't loose
New fancy seat ordered through @Delta VS With the correct planted seat bracket.
also made a new arm rest
May 2023
Installed an aux beam panel
Installed @eimkeith rear lower control am brackets
June 2023
Early dash ashtray mount fir switch pros
Lost some bolts on the bead locks.
Installed some tweeters on my mounts.
Put in this beast of a skid plate, this is the back half from @Delta VS
Full coverage
I have landed and pivoted on this several times
July 2023
Made a campfire box
@eimkeith is going to make a nicer one.
Rear panel made
Went to expo bend with @Delta VS
Then went to slick rock and fixed @jcardona1
With the bun trail welder.
Sue Bunn is having some health issues donate if you can. They are awesome people and have helped countless on trail.
Sept 2023
Added hydro assist
Then Rubicon with Tlca and Rubithon!
That's Lee Hill near buck island, I didn't make up thir or soupbowl.
This is testing for the @Delta VS skids
confirmed you can scratch them.
i have this much droop if your wondering..
Then I broke the rear sway bar heavy duty whiteline at slick rock
Weird...
November 2023
Camp trip to Usal
Made a drill guide to tap boxes for hydro assist.
Swapped in some new tie rod and drag links from @Delta VS
These are 7075 aluminum and very nice
Started on a front anti sway bar.
