Both the Choke Breaker and the Throttle Positioner are operated by the vac at the carb base. I'm not sure about a "vacuum valve." Those links can be bent, but, the adjustment for the Throttle Positioner is the rpm-adjusting screw, and the Choke Breaker is set with the link so that it opens the choke butterfly 38 deg. from bore, according to factory specs.
Basically, you probably need to do nothing other than make sure that the adjustment screw tip is riding on the throttle valve lever, and make the engine run at the right rpm.
@Pighead It isn't an idle speed, it is an amount of throttle opened when the starter is cranking. The FSM has you open it to a certain amount, and that is that number on a warm motor.
