Whirly Bird this looks awesome! I have the no-cut on order for my white LX, still need to make a decision on a front bumper. Do you have a build thread or can you post some more pics of the front end?
Does anyone have any pics or details they can share of their accessory panel/ladder? I'm currently planning on creating a weather resistant "box" (or just very lightly shielded box) out of the lower half for a battery and ARB compressor. I'm curious what others have done.
Cool idea @suprarx7nut just buy a sheet of ABS plastic and bend it to shape around your gear. I'd want that stuff out of sight to keep honest folks honest. Maybe plumb the compressor connection out the side of the "ladder/enclosure" leaving the compressor and battery hidden. The wire management is the only foreseeable hassle with that design. Buy QUALITY cable that can take the bend cycle it will be up against in that location.
I just bought a Kenwood camera and mounted it right on the bumper. Much better display.
No, however the max capacity is not an issue with the provided tow package. Also through bolts can be added that would likely increase the capacity beyond the factory tow hitch.
From all of the pictures I've seen, it appears that the spare tire area is retained. I'm going to run two spares in that caseI forgot I can search within a thread for text, rather than the whole 100 forum. I found the post above which answers my towing question - 6500 lb factory tow rating is retaining with this bumper and "tow package" (is that an option or standard?).
AND fit spare tire under truck still? Very tempting for my needs.
Yup. I’m running two spares with this bumper. 285/75/16 KO2.From all of the pictures I've seen, it appears that the spare tire area is retained. I'm going two run to spares in that case
what's the difference between this one and the modular one?
Looks good. Are the bumpers black or gray?
Thanks for the reply. I don't have it, is it optional?I mounted using the supplied mount.
I need to contact Ben at @Dissent I guess
