Has anyone installed these with a body lift? Is it possible to order with body lift accounted for (having bumpers moved up relative to their mount points)?
I connected the two lights and ran a wire up to the drivers side tail light and tapped it there. So far no issues.How is everyone wiring the included LED reverse lights? Are you guys tapping into the factory reverse light wiring (by the factory jack wiring or by the reverse light wiring in the tailgate) for power or are you guys going the running power from the battery and going the relay route?
You’ll need to call @benc but from what I remember. There was a mud member who got a set front and back which accounted for a 1” body lift. Good Luck!Has anyone installed these with a body lift? Is it possible to order with body lift accounted for (having bumpers moved up relative to their mount points)?
This worked.@benc What lug nuts did you use to mount Rock Warrior wheels on one of your builds? The ones provided with tire carrier are too big and the ones I bought at autozone fit but can’t put a socket on to tighten.
I have a 35x12.50x18 mounted on mine without problems.
I removed my tire and gas strut and tightened the bearing until the swingarm had enough drag to not move when I let it goJust finished installing mine. The tips in this thread were extremely helpful. How much did everyone tighten the swing arm bearing? My swingarm with no gas strut closed slowly when I let it go. I probably turned mine 1/2 rotation clockwise, which dramatically slowed down the arm closing. Is that enough or should I load the bearing more? For reference, The strike pad barely touched grazed the stainless pad with no tire on the swingarm. Now with the tire, it climbs the stainless pad about 1-2mm.
Here's a link to the current 97lb strut we currently supply.Can anyone screenshot or give me the specs on the gas strut ? One of mine gave out and I need to buy a replacement and a spare. My other one is illegible.
Amazon product ASIN B09WDTBCFM
We've also used 150 lb struts in the past
Yeah I have the 150's, those things are BEAST. Almost killed a kid. Think I'll downgrade. Thanks!
Ha they are nice to keep the arm open if on a trail at an angle but definitely have some pressure.
For the 97s just a heads up I think you'll need to move the ball stud on the swing arm to the further mounting position.
We source those ball studs from mcmaster carr and it is their part # 9512K73Can you also tell me where I buy replacement little "nubs" that these attach to? I managed to break one.. Thanks for the help again.
