Call or email @bencDoes anyone have an extra swingout strut by chance? I had one snap and the website doesn’t have the part available.
When I needed a spare part, he mailed it out right away.
I had this problem before and if you look back in this thread I posted about it. There are two rubber stoppers on the swingout....one is much thicker than the other, you have them installed in the wrong places. Install the thinner rubber stopper on the outside of the arm and the thicker one on the inside of the swing arm to provide more clearance to open and close the table with the lower tailgate open.Dumb question. Is the table on the tire carrier only accessible with the tailgate up? I can’t figure any other way. There’s contact with the tail get down. And contact with the table deployed, trying to open the tailgate.
Thanks. I measured both bump stops earlier and they’re the same thickness. I even switch their positions. Same stamped number for all. Likely got all the same thickness. I guess I’ll dissent a call.I had this problem before and if you look back in this thread I posted about it. There are two rubber stoppers on the swingout....one is much thicker than the other, you have them installed in the wrong places. Install the thinner rubber stopper on the outside of the arm and the thicker one on the inside of the swing arm to provide more clearance to open and close the table with the lower tailgate open.
Yes call Ben. Should be two different thickness stops. Here are old pics I took of mine and when the thicker stop is installed on outside of swing arm, table doesn’t open and close with lower tailgate open.
Call or email @benc
Developed a squeak sound on tire carrier, any ideas? It's less than 500miles highways after installation.
Contacted Dissent and recommended to cut off a small portion of the pinch weld of the body to make some space. Did that and no touching, no squeak now.Found the culprit, bumper in touch with the body here on both sides
View attachment 2455367View attachment 2455368
I put a bit of lithium grease and squeak gone! Bumper should not touch the frame I believe, anything wrong with the installation? Or is it same for others?
Anyone running a snowboard/ski carrier via the hitch mounts? Curious what everyone is running
I made a little arm to use my yakima clamps. Took a coupe hours. It's okay, but I have to watch my head when reaching in for the levers.
The wavian should work fine. I am using scepter here.Might sound like a noob question but does anyone have any photos of the 3 jerry can holder with fuel cans in it? I was thinking about ordering three 5gal Wavian Fuel Cans down the road once I get my bumper in and wanted to be sure that standard size can is what works best!
