- Thread starter
- #61
Here's a pic of where I mounted the fuel pump relay. You may also notice the dirty blower motor. Since it was right there in my face I decided to clean it up. A trip to the parts washer, wire brush, sand paper and then paint.
Nice job! I'm watching closely to this one.....I'll be swapping a TBI v8 into my cruiser soon. Anyway I have done the 4.3 TBI conversion on my jheep CJ7 and, while I know it's a little different application, both the carter and 8153 fuel pumps gave me serious problems at WOT and on grades such as Kinsbury and spooner. Fed up, I called the guys at Howell injection and the guy told me that, while these fuel pumps are deigned for TBI units, they are rated at max psi on a good cool day and when they get heated they won't produce the psi needed under WOT. He told me to put a fuel pressure gauge on there, drive it around and see for myself and he was right. That 8153 after running for a while was only putting out 10 psi and when I romped on it would drop to 2 psi causing stuttering and sputtering. So I got the Howell fuel pump rated at 35psi and it has worked great. I also asked if there was going to be a problem with the fuel pump putting out more pressure than needed and he said no. The TBI unit has a pressure reducer built in and any extra fuel goes out the return line and back in your tank. He also mentioned that the fuel pump stays cooler and lasts longer cause it doesn't have to achieve it's max everytime it's used. Just throwin it out there in case you come into the same problems I did.....I actually threw the carter away when I was mad but am keeping the 8153 around as trail spare....
.just wondering if you used a special fitting for the tbi fuel ports to go to the rubber hose and if so where from
Cleaned up the fuel tank straps as best I could. Primed and painted them. Then reinstalled the gas tank and plumbed the fuel lines (I didn't forget the grommets!). The previous owner had installed a bucket seat so that it sat directly on top of the tank bearing the entire weight of the passenger - no other support at all. It's no wonder it was leaking fuel at the seams. I will be looking for a stock bench seat to replace it.
I put 5 gallons of fuel in this morning. So far no leaks!
So in the picture with the gas tank, which one is the fuel line and which one is the return line?
I'm in the middle of doing the same thing. But stuck on the wiring harness. can you post where you got your scamatic for the wiring? Or can you post a detailed diagram of yours? So far your post are great. I have had all the stuff for quite sometime but started doing after seeing your post now I'm stuck on the wiring. any help would be great. keep up the good work.
I'd add a fuel pressure gauge.
You also have a lot of elbows in the return. If you find your fuel pressure is to high it's probably because of a restriction in the return line.
Um you are going to want to put that O2 sensor where it can get a reading from both headers. Putting it on one side means that the computer is only going to get feedback from one side.
