so I built my cruiser up over the years from many different parts and its worked quite well with soa 305qjet stock 4spd and 4.10s welded rear with 60 srprings and traction bar on 37s. but the qjet just wasnt as good as i wanted when in real steep situations aswell the gearing just wasnt enough.
so i figured it was time change a few things around so i aquired a recently rebuilt 350 tbi from an 89 burban, sm465 and a 3spd case i had kicking around. and now ive finally been getting enough time to work on it. so as it sits now i have tubed the front end and done a shackle reversal moving the front end forward about 4 inches. modified some of the sheet metal to fit back in around the tube. welded the spiders in the front third and a built a long spline cv driveshaft with the trail gear kit and a minitruck cv. the tbi motor is in and almost ready to be wired up. i bought a howell harness to try to speed things up but still have to cut into it and adjust some of the wires. made a twinstick for the 465/3spd and waiting on a clip and pivot ball for a cast clutch fork
also decided to tap the steering box for ram assist
