I don't think it matters. Every other setup I've seen on a V8 has it on one side or the other.
That is definitely not what I have seen. You are essentially ignoring the feedback from half of your engine. I would put it further down where the pipes cross over.
Quite often ecm signals are asserted as gnd/(-). I think this is one of them. Try running 12v to the SES light then back to the ecm.
.I forgot to mention it, but the 12v to SES light should probably be switched 12v (IGN). I've been looking at wiring diagrams tonight since I can't remember for sure. Haven't been able to confirm it. If you have a wiring diagram check to be sure. Constant 12v probably won't hurt anything at this stage in any case.
nice cupholders.
I have given a lot of thought to the wiring harness and whether to go with a Painless or use the stock GM harness. Here's the argument as I see it:
Painless= easier installation with new wires/connectors
GM= great price! PITA installation with old wires/connectors
I have nearly zero experience with automotive wiring until this project, so the idea of tearing into the stock harness is intimidating as hell. $370.00 for the Painless may save me weeks (or months) of cursing and spitting in my driveway.
On the other hand, there is loads of information out there from others who have used the stock harness including wiring diagrams, etc. and I would like to put that $370 towards something a little more sexy (new shocks would be nice!). With that in mind I started looking at the harness.
The connectors are all very self explanatory as to where they are supposed to go. I connected everything I could on the intake manifold and labeled it. There are a few cut wires and I am very concerned that the connectors to the fuel injectors look a bit melted (kinda tough to see in pics). Should I find new ones?
I decided on the Airtex E8153. I read comments on the Pirate 4x4 forum that others who have also done the GM TBI conversion have had good success with this pump. I found it on Amazon.com, of all places, for a mere $54.00. I hope it delivers adequate pressure. it was such a good price I figure if it doesn't I'm not really out much money.
Will post more pics of my progress soon.
With the tan wire disconnected set base timing to 0 degres. ECM is real picky about this... it needs to be exactly 0 degrees. I did not catch what type transmission you have but I'm sure you'll need to look into a VSS setup (vehicle speed sensor).
. Will post more on that later.walbro is a good brand to look for in eletric fuel pumps.
