I guess I should be running it straight to the ecm and not through the dakota digital converter? My ecm is not getting a correct speed reading from the vss. it is reading about half the speed I'm actually moving and doesn't even register until after 17mph. Would this problem give me the idle and stalling problems that I'm having also?
Ed -
You have a PM.
Nick
Ed, swapped out IAC but did not do the reset. My TPS is not the adjustable type (though, I have been thinking of switching to one). I just xfered to Hawaii this last fall, if I was still in Sacto I would have liked to have driven out to Reno and helped you with your TC. I'm ditching the whole Digital Dakota setup and doing the same VSS setup you are running. thanks for the help and I will keep you posted. You writeup is awesome! Digger.
When I did the TBI conversion on my cruiser I left the EGR and sensor hooked up. Does the computer not give you error codes if you remove these pieces? If so did you have that programmed out?
Thanks this is a really helpful build thread.
Jack
How do you know it is running rich?
Hi,did you had more power running with the carb or now with the tbi?
