Builds Meet Steve
So ground off as much mouse pee rust as I could, put first cat of rust converter on, then remembered I have this tube for spraying in areas not reachable with spray, put this down pillars in everyborifice I could find on the roof of this pig, converter running out all over, I think I soaked it, tomorrow 2nd coat. It does smell-probably some chemistry with mouse urine, Greek to me!
If you look a few pages in on my thread I used corroseal and then later wet sanded the paint to remove the corroseal stain from the non rusty areas. It turned out pretty well. I like the finish that the corroseal leaves on the rusty areas.
no cracks at hinge locations on doors, a little rust down low, but that will have to wait. waiting for some rust converter, so today with a cold beer, removed all seam sealer from gutters, a little rust under, think I will treat with POR 15, paint and reseal, thoughts?
POR15 would ideally WANT the rust to bond to. Not sure how it would adhere to a rust converter. If you decide to try it, maybe run a tape line as low as possible and then use a brush to apply. After it’s dried apply the seam sealer, and then maybe spray the sealer with rattle-can that resembles the factory paint as close as you can find.
Take that with a grain of salt, and maybe others with better ideas will chime in. I’m just thinking do whatever you can do to keep the “repair work” to a visual minimum.
I know the por15 type products don't like to stick to other type paints unless prepared right, so would that effect the seam sealer the same?
