making your own soft top.. because lets be honest.. you've built everything else (1 Viewer)
Hmm try the pictures again..
:cool:
I just came across this thread and I must say! Well done!! Looks like your having a great time!
We have been working on building our first custom paki top bow set, and having a good old time with it!!
Justin
Great job, nice work
Thanks guys! I'm going to try to make the A-type soft top next probably only be a 5 window top though... man I hate doing the windows. The SOR soft top and many modern convertibles I see have the windows melted to the actual fabric for a lack of better description. Does anyone know what I'm talking about? This would make installing windows much easier.
i'll trade you a pair of fiberglass fenders for it :D
hah! they look much better on your truck then they did here...
Very nice. That turned out amazing. How many yards of fabric did you end up using? Was the Top Gun fabric you used 60" wide?
you have to make sure you get all one piece of fabric because you'll need two lengths of 80" about 35" wide. Since the Top Gun was 60" wide that requires almost 4.5 yards just for the top piece.
my problem was they ran out of the roll and I thought I would be alright.
To be safe I would say 5.5-6 yards of fabric. But you will have extra
Dielectric heat sealed ... Also called fusion welded or just welded
Machines are expensive usually a die at the size of the window is used for mass production... Smaller roller machines are available however... One slip... You can't just unstitch and fix... It's permanent
Not on canvas ... If... It's coated with a petroleum based product...
The other thought you want to remember is that ... IF... You damage a window ( hole crack or rip ) you can easily unstitch and restitch in a new window... Can't do that with a window weld... You would be able to stitch around and have a window that's stiched in over... But ... Would not match the rest on style and would need to be a bit larger to adhear to the vinyl/canvas
You can't simply weld on top of the old welding AFAIK ... But you could cut out at the weld and weld in a new larger window.
Kinda make sence?
It does have its advantages... But disadvantages as well
