- Thread starter
- #21
Seat-of-the-pants data is it moves a lot more air. I need to hitch up the Kimberley and do some low-speed pulling with it.
What drove me to look for a solution that allowed the use of the stock fan was the common complaint that SC engines run hot while their TC counter parts did not even at higher boost.
The fact that the stock fan got changed out during the installation process seemed to be a likely candidate for being the culprit. However definitive data is likely months away.
Right now they are in "shake down" testing. I wanted to make sure there was proper clearances and try to get an idea on any performance gains as well. After the first of the year I'll have a batch ready to go.
we haven't had any problems with the 3FE fan in the three years we've had the 80 and the one year in the LX
inkpot has been running his 3FE fan for even longer
I see in your sig line you are a member of copper state Cruisers so I'll assume you live in Arizona.
One thing you need to understand is that the thermal conductivity of air decreases as it's humidity increases. So while Arizona might have higher than average temperatures it also has lower than average humidity. So while it is a hot environment it is also the best one for cooling as well.
The worst environment would be Miami or New England with near 100% humidity and temps over 100* at times.
my basic understanding is that while air with a higher humidity level can store more heat the rate of transfer is also effected and slowed by it.
