- Joined
- Sep 9, 2004
- Threads
- 196
- Messages
- 12,499
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
Never seen a frame chop done in that location.
Cheers
Cheers
@SNLC
1)it’s one of the few straight places in the frame
2) the 80 frame isn’t rectangular tubing, it’s two “C” Channel, one slightly larger than the other welded together. there was a factory seam here on the inside that I used and re-welded after shortening
3) the radius arm mount acts like a scab plate on the outside and bottom of the fame
I never claimed to be smart or right! Just how I did it![]()
Yup, done a few myself. I cut them at the rear lower control arm mount. The only issues I see with where you cut it is trans crossmember but that doesn't really matter in your build.
Cheers
I went through a ton of cut off wheels getting that damn crossmember mount off and out!
Whoever welded it on took his job very seriously!
have a pic of your cut?
thanks
That tank is huge, maybe cut some out and angle it up towards the rear?
@SNLC I give my rig this look a lot too!
i need to read your and @2fpower whole threads!
You need to beef up those transfer case frame mounts.
Why not just relocate the oil filter? Or look for a shorter oil filter? Probably would have made your life easier.
Same deal with the dual transfer cases, what's the deal with the duals vs just a single 4.7?
