Builds it has begun (1 Viewer)
looks good
where are you located? just curious as I'm from the east coast of Canada too
Dartmouth,NS...what you doing in Whitehorse?...Aviation?
Daryl
Your rig looks good. My folks are from Sydney, Cape Breton. I'm due to visit in May. We used to go back every summer and spend spend time on the Bras d'Or lakes. Got some cousins in Halifax, probably not too far from yourself.
spring weren't stiff enough? coils in front? could they have added to coils after the engine swap?
Daryl
just kind of ended up here, I'm originally from Wolfville NS, we're hoping to get back this summer for a visit, but not sure if it's going to happen.
:beer:
got some more work done the past wek. These clips for holding work quite well. I am happy with the result:beer: :beer:
Daryl
now?
more
last one
lincoln migpak 10...110 volt....025 wire with 75/25 gas.
Daryl
updates soon!
Daryl
here is the rear sill cover. cleans it up nicely.
Man this is a slow process!!!!
Daryl
Hi All:
Great sheet metal work!
Thanks for sharing your project with us! :cheers:
Regards,
Alan
was wondering about that paint.. you used on the frame and tub.... do you have a part number and brand for it.....
were did you buy it from....
thanks
The frame paint is a International Protective Coatings product.( made by International Paints ) It is Interseal 670hs. It is a 2 component high build , high solids surface tolerant epoxy.
If you want a smooth coating then this is not the stuff for you. It is as thick as peanut butter! So when you put it on you roll it or brush it and it will leave a bumpy surface...looks like bed liner.
But this is the stuff they use on off-shore oil rigs so it should be pretty durable.:)
I purchased it right from the International dealer.
Daryl
