OK so today I planned on taking the hub flange off an getting to the bearing preload to tighten it up but I've run into a little problem. When attempting to take the nuts and cone washers off, I got two that came off the way they should, but then I had two that for some reason removed the whole stud. I assumed I could just use some locitite or something on those studs any input there would be helpful. But the bigger problem right now is the two other studs that I can't get off what so ever. I can turn them but they just spin on the stud. I assume this means the threads are toast and I'll have to get some more but how in the he'll do I get them off? This is my first time trying to get the hub off since I've owned the truck but it appears like the PO had these nuts on there pretty tight and possibly caused them to do this.
