Redneck approved!
Will suck balls when you have to take it apart
I guess I shouldve also mentioned that this is temporary. I will be rebuilding the knuckles as well as upgrading to RCVs this summer. I don’t wheel it as much as I used to just due to living back down in the city and I am busy with work as well. I do appreciate your concern but rest assured if most goes according to plan, the front end should be redone by JuneNeither Purist and "OEM is king" are anything I will ever be accused of. But just because something is cheap does not mean it is a good idea. Even IF those welds will hold over time... do you not ever plan to do any maintenance? Do you think that your style (apparently from your comments and IG posts) of "bash it harder" wheeling will not lead to anything in that front axle needing attention? Never gonna break a birfield on the trail? Never gonna need to check/adjust wheel bearings, or replace water contaminated grease?Did you install new rotors before you broke out the hot glue gun?
I get that you are 21 years old and want to beat the snot out of your rig... I mean "push it to its limits". Been there done that myself. But this was really not a choice you will consider something to brag about in the future. To save less than $100 you have cost yourself a lot more money and potentially a LOT of unneeded effort just to deal with routine things by taking this ill considered approach.
Mark...
Had he mentioned the birf splines were also toast and that he is redoing everything in June, there may have been a different response. Out the gate, it was simply "my flanges stripped so I welded them to my birfs"I guess I don't see what the problem is. You needed flanges and shafts anyway.
Yeah hopefully it wont be too bad. Just a cutoff after the welds should free everything up!Redneck approved!
Absolutely relies on the weld but so far so good its gone about 4 hours of wheeling it harder than I have ever done before. Im keeping my fingers crossed and I hope you can do the same haha!Had he mentioned the birf splines were also toast, there may have been a slightly different response, knowing everything needed to be replaced regardless. However I'd just point to @Mark W 's post for trail/etc concerns. If it doesn't break until he replaces everything, fair enough, but it relies on that weld.
Hah, agreed.Absolutely relies on the weld but so far so good its gone about 4 hours of wheeling it harder than I have ever done before. Im keeping my fingers crossed and I hope you can do the same haha!
Ill edit the post nowHah, agreed.
Maybe in the future, start off with all the info![]()
I guess I took that as an assumed fact before he mentioned it... I figured if the flanges were shot enough to need the fix, then the axles were almost definitely shot as well. The moment when the money could have been saved was some time before the front axle stopped transferring power! Then again, I look at broken s*** for a living, I'm used to thinking about what else would have broken.Had he mentioned the birf splines were also toast and that he is redoing everything in June, there may have been a different response. Out the gate, it was simply "my flanges stripped so I welded them to my birfs"
Yeah I daily drove it for a few months with no wheeling and didn’t find out that it was shot til I was going up muddy slope on a trailI guess I took that as an assumed fact before he mentioned it... I figured if the flanges were shot enough to need the fix, then the axles were almost definitely shot as well. The moment when the money could have been saved was some time before the front axle stopped transferring power! Then again, I look at broken s*** for a living, I'm used to thinking about what else would have broken.
These things happen... I'd be a liar if I said I'd never missed something like that.Yeah I daily drove it for a few months with no wheeling and didn’t find out that it was shot til I was going up muddy slope on a trail
Nice, push the the truck until the birf grenades on the trail. That usually means the tire won’t rotate and the wheel won’t turn.Absolutely relies on the weld but so far so good its gone about 4 hours of wheeling it harder than I have ever done before. Im keeping my fingers crossed and I hope you can do the same haha!
It was a last dich effort to be available to do a trail one night. This isnt a fix to continue hard wheeling every weekend or anything of that sort. I don’t crawl, its mostly just mud trails or snow wheeling with some occasional crawling. I understand the risk Im taking but I also know what I am doing. I built this truck with my own 2 hands and feel confident in what I do.Nice, push the the truck until the birf grenades on the trail. That usually means the tire won’t rotate and the wheel won’t turn.
ruin the days fun for everyone.
When I first saw it, I was like WTF?!?!?!It was a last dich effort to be available to do a trail one night. This isnt a fix to continue hard wheeling every weekend or anything of that sort. I don’t crawl, its mostly just mud trails or snow wheeling with some occasional crawling. I understand the risk Im taking but I also know what I am doing. I built this truck with my own 2 hands and feel confident in what I do.
-J
Yeah absolutely! I’m apart of the Norcal Bay Area Land Cruiser group and we have a pretty solid groupchat going and I consulted with them prior to making a decision on it.When I first saw it, I was like WTF?!?!?!
However, after understanding that both the birf and the flange were stripped, it's a fix. Yes, you'll need a cutoff wheel to cut off the end of the axle to get it all apart.
I don't recommend driving much on pavement in that condition, although make sure your VC is not locked. What it doesn't allow is floating movement for the birfield, so it's forcing the slipping action to take place inside your differential. You may tend to bind a bit more in the actual birf, so higher risk of shattering a birf if you're steering a lot when doing it.
It's not the end of the world, but it's a good "field fix" to get you by until other parts are available.
You're obviously pushing it pretty hard anyway if you stripped the drive flanges and birf to that point.
Old lady around the corner had 5 or 6 she posted on FB for free so I went and got one for me and my brother hahaI'm just wondering where you cut down the fake Christmas tree.![]()
