DanS HJ-45
- Thread starter
- #361
The other bit of fab work I did was to make an "overhead" panel for lights. There is a big dome light, and two little spot/map lights. All of them are LED, and all powered with the ACC position of the key, so that you could conceivably leave the lights on for quite some time (days and days) without worrying about the ability to start.
The lights all came from Aircraft Spruce and Specialty.
The dome light is just a 12 LED white unit. It's very, very bright at night. Very easily lights up the whole inside of the truck.
LED CABIN LIGHTS from Aircraft Spruce
The spot/map lights are really cool. They have both red and white lights (which are switched separately in our case). Amazingly bright little spot lights.
754 SERIES LED COCKPIT LIGHTS from Aircraft Spruce
But enough about the lights, here are pictures...
Here's the panel. I'll talk about the "switchology" in a second... It is removable, I just welded tabs onto the cabe spreader bars that it bolts into, for ease of maintenance.
And here's two pictures of the lights and switches installed in the panel. The center button is square, and turns the dome light on and off. The round switches are used to control the spot lights. I painted the buttons on two of the switches white, so to turn on the white spot light you press the white button, and to turn on the red spot you press the red button. You can have both on at the same time if you choose (don't know why, the white overpowers the red, but it's easier to wire this way anyway).
On the rear of the panel there are two threaded screw holes for the external speaker (for either the CB or HAM radio).
That's it for the pictures I've got on the computer.
Here's what's left before the 40 gets painted and put back together:
After that the body comes off and everything gets painted for the final time and put back together. Sounds simple with that list, doesn't it?
Dan
- Cut out rust in the bed floor (I'm going to fabricate a tool box in the floor)
- Finish the tailgate door
- Attach the soft top windshield channel (we ordered one from Shane/AATLAS1X)
- Add the footman loops and twist locks for the soft top
- Attach the alternator permanently. I'm having a problem with the '79 alternator plug coming part. All I need to do is remove the spades from the plug and insert them into the other plug
- I've got to figure out why the ammeter doesn't work, what's shorting out in the rear diff lock wiring, and why the fuse for the panel lighting blows (I think I touched a part to the frame and blew the 5A fuse, but I want to be sure)
Dan
