- Thread starter
- #21
No need. Easier to clean properly when separated.
rebuilding the left front knuckle on my FJ43. Restorers didn't include cone washers on hub assembly, and that caused things to fall apart while driving. So, on that, I can't seem to find a replacement kit for those smaller bolts and cone washers (I can find the larger ones that go on the arm up top and below the knuckle. Any ideas out there?
awesome! Found them at MarlinCrawler.com. Thanks for the note. Related to this, I'm replacing stuff that was obviously damaged - threads to the spindle, the flange especially, the 54mm nuts within the hub. The splines on the CV took a little scoring...but I'm kind of on the fence on whether to replace it. The assembly up to the dust cover has been seemingly recently done, and I'd think if I break it down further, that'll drive replacement of all kinds of stuff downstream. Any advice is welcome.BOLT, STUD (FOR FRONT AXLE OUTER SHAFT FLANGE)
90116-08325
WASHER, CONE (FOR FRONT AXLE SHAFT)
42323-60010
You can get those from any Toyota dealer.
Not the arms, the hub assembly that mounts to the rotor, where the hub flange mounts on top. Nonetheless, yeah, I bought this from a dealer who seemed to know a lot about the resto...and it certainly looked good everywhere elseYour restorer didn't install the cone washers holding the steering arms on? If so, that's some scary stuff.
I don't know that Warn hubs used cone washers. i have seen plenty Warn hubs with those little locking tab things
