looks ok to me. i’d sand it but the wipers will still seal it
I got my knuckle back on. Put the shims back in as they were. Torqued both top and bottom to 71 ft lbs. The pre-load only measures at 3.58 lbs. What to do now ?
Yep. New bearings packed with grease. 2 on top. 1 on bottom.
I'll be doing a knuckle swap in the near future and im curious. If you remove a shim from the bottom of the knuckle to achieve preload, wouldn't that make the knuckle slightly off center in relation to the inner axle seal because the weight of the vehicle is being supported by the lower bearing?
Yes. I thought about accuracy of the scale. I checked it and it's not perfect but pretty close. Yes. The pre-load is supposed to be 6.6 to 13 lbs. There were no shims in the knuckle. Just on the outside. 2 on top and one on bottom. Changing the shims will effect the centering of the axle shaft, will it not?
I used the same shims that were in it before. My kit from Cruiser Outfitters came with quite a few shims of varying thickness. I'm wondering if I should use a combination of shims that end up slightly thinner for both top and bottom???
forum.ih8mud.com
Yep. Clean and repack. Moly is almost worthless in a bearingOn another note. I got in a hurry packing bearings and packed my wheel bearings with the same molly grease as the knuckle bearings. Oops. Should I de-gease them and repack with the high temp or leave them? What's better?
really? moly is supposed to be really good for pressure and heat from my readingYep. Clean and repack. Moly is almost worthless in a bearing
